Author Topic: Convolution extension - negative values  (Read 6884 times)
Offline darkownt
« on: 2009 December 05 09:28:08 »
Hi:
I'd like the image.convolution JavaScript command to be extended to be able to utilize negative values in the convolution kernal.
I would also request that the convolution process/interface that is introduced at a later date into the PixInsight core also include the capability to utilize negative values.
cheers
Colin
Re: Convolution extension - negative values
« Reply #1 on: 2009 December 05 11:12:53 »
Hi Colin,
Image.convolve() can be used with any kernel element values. When a kernel filter has negative values, you must specify a kernel weight explicitly. For example:
var sharpen = [ 0, -1,  0,
               -1,  5, -1,
                0, -1,  0 ];
var view = ImageWindow.activeWindow.currentView;
with ( view )
   beginProcess();
   image.convolve( sharpen, 1.0 ); // explicit unit kernel weight
   endProcess();
You can specify other weights, not necessarily one, depending on your filter and what you want to achieve.
Open an image and run this little script. It applies a classical sharpen filter.
Feel free to play with different kernel filters. Note that the above sharpen filter preserves flux because the sum of its elements is one.
(edited: fixed wrong filter elements)
« Last Edit: 2009 December 05 11:39:03 by Juan Conejero »
Offline darkownt
« Reply #2 on: 2009 December 07 14:03:39 »
Thanks Juan!
I've added that into my script.
BTW Is there any image format that supports negative values produced by PixelMath?  A-B seems to truncate values where B>A...
I'm trying to generate convolution filters with + and - numbers from images with + and - numbers in them.
I have a script which can take an image and use it as the convolution kernal.  To get my negative numbers, in the script I shift the image by a value (usually the negative of the median) to get my convolution filter just before I apply it.  It would be much easier to use pixel math to create a zero centered + and - image, before applying my script without the shift.
cheers
Colin
« Reply #3 on: 2009 December 10 14:17:23 »
Hi Colin
If you avoid PixelMath, i.e. manually operate the images/pixels (not sure if this works with JavaScrip... I do that all the time with C++/PCL), any floating point format is capable of negative values support. They will be displayed oddly, but, it works.
