Author Topic: Spectrum  (Read 4366 times)
Offline shold
    • http://www.flickr.com/photos/siegi252
Spectrum
« on: 2009 November 28 01:22:19 »
is it possible to edit a 2D spectrum image in PixInsight ?
greetings
Siegfried
Re: Spectrum
« Reply #1 on: 2009 November 28 07:17:23 »
What is a 2D spectrum image ?  >:D
Offline shold
Re: Spectrum
« Reply #2 on: 2010 January 02 04:59:07 »
1. it is possible to develop a spectrum in PIX?
2. It is possible to aggregate multiple spectra stripes?
The spectrum is annexed by the Sun in H alpha
Linear dispersion of 0.07 angstroms
Best Regards
Siegfried
Re: Spectrum
« Reply #3 on: 2010 January 02 05:21:00 »
Hi Siegfried
We have not developed tools specifically for spectra. As you know, they may be considered as 1d images, when reduced/calibrated. So, working with spectra may be divided into two branches: dealing with the 2d data, from the "real" images, or process the 1d reduced data (which at the end may be ploted). We have plans for all of this, but have a very low priority right now.
About reading, since raw data is just as any other fits image, there should be no problem at all to display the 2d data as a common image.
Offline shold
Re: Spectrum
« Reply #4 on: 2010 January 02 05:54:53 »
Hi Carlos,
I tried it with deconvolution, with faint lines, there is an advantage.
Regards
Siegfried
Re: Spectrum
« Reply #5 on: 2010 January 02 12:43:47 »
I'm glad to hear that. I guess that a 1d PSF may be work better in this case. You may create it with PixelMath, or a script, and then load it to any of our deconvolution tools as a external psf image.
