Author Topic: Image container and debayer  (Read 6794 times)
Offline Harry page
« on: 2009 November 10 11:30:48 »
I am having a problem using the image container and the debayer module , being that I can not get it to save the debayered images it will only save grey images
I did not have a problem with the previous version of Pi
For the record I do the following
1) Select my unconverted images
2) select a out put directory
3) Put the image container instance on the debayer mod and let it run
I then get RGB images on the screen and grey images saved in the selected directory
I am sorry if its Me  :footinmouth:
Harry
Harry Page
Re: Image container and debayer
« Reply #1 on: 2009 November 10 11:44:08 »
Hi Harry,
I'll admit I never tried this before :) Indeed I see the same result as you. I probably implemented something incorrectly in the module. I hope Juan or someone else can give a hint so I can fix it.
« Reply #2 on: 2009 November 10 11:48:28 »
Hi Harry,
I think I understand the problem. Debayer doesn't modify the existing image, it creates a new one. Image Container doesn't know this and simply saves the unmodified input file.
Debayer will need an option to modify the input file.
Offline Harry page
« Reply #3 on: 2009 November 10 12:03:09 »
Hi Sander
Thanks for looking at this problem
I am sure it worked in previous Pi ver , but perhapes my memory has failed  ???
Is this a sander or Juan Fix ?
Harry
Harry Page
« Reply #4 on: 2009 November 10 12:04:31 »
If my description of the problem is correct then it's a Sander fix. Image Container has no idea that Debayer created new files.
Offline NKV
« Reply #5 on: 2009 December 15 00:18:01 »
Any news?
« Reply #6 on: 2009 December 15 07:34:13 »
Sorry, no news :)
