Author Topic: STF sliders misbehaviour  (Read 4114 times)
Offline David Serrano
« on: 2009 November 06 10:09:12 »
Long time! ;)
This is about STF, I've managed to break it:
- Click near the shadows slider. It goes to 0.05 or so.
- Click-and-drag the midtones slider to 0.00. That's to say, click near it and drag it to the point where it matches the shadows slider.
- Click anywhere near this point:
  - If clicking at the left, I would expect to adjust the shadows slider.
  - If clicking at the right, I would expect to adjust the midtones slider.
  - However, in any case, it's the highlights slider that is adjusted.
From this point on, you can't adjust the shadows or midtones slider, only the highlites one. You can restore the entire GUI  using the usual restore button at the lower right corner.
The status of "Link RGB channels" doesn't make any difference.
 David Serrano
Re: STF sliders misbehaviour
« Reply #1 on: 2009 November 06 11:34:11 »
Hi David,
Confirmed, you broke it! :)
Thanks for catching this glitch; I'll try to fix it in version 1.6.
« Reply #2 on: 2009 November 06 13:47:12 »
Bah "I'll try I'll try"... we know you'll do it ;)
 David Serrano
« Reply #3 on: 2009 November 09 11:19:46 »
David: manos de hacha ;)
« Reply #4 on: 2009 November 09 14:52:40 »
Jijiji es que yo exprimo las herramientas que tengo en las manos ;).
Just in case this went unnoticed, I tried the reverse:
- Click near the highlights, so it goes to around 0.95.
- Click-and-drag the midtones to 1.00, ie to match highlights.
  - From now on, the midtones can't be adjusted (but shadows can, which is in contrast with the other case).
 David Serrano
