We have detected a problem that prevents execution of PixInsight 1.5.9 for 32-bit Windows on old AMD and Intel processors.
Inadvertently, the LCMS support library for Windows versions of PixInsight 1.5.9 was compiled with SSE2 instruction support. SSE2 instructions are not supported by the following processors:
- AMD processors prior to Athlon 64, including all Socket A-based processors.
- Intel processors prior to Pentium 4.
If you have one of these processors, PixInsight's color management subsystem, as well as several file-format support and process modules, won't work on your computer.
If you have a newer processor with SSE2 support, please ignore this post.The fix is very easy. Please follow these steps:
1. If you have PixInsight running, exit it.
2. Download this file:
http://pixinsight.com/export/1.5.9-bugfix/lcms-pxi.dll.zip
3. Uncompress the zip archive. This will give you a lcms-pxi.dll file.
4. If you installed PixInsight on the default location, it is on your C:\PCL folder. Please launch the Windows Explorer and locate the following folder:
C:\PCL\bin
If you installed on a custom location, change the folder above to its counterpart on your custom installation folder.
5. Copy the new lcms-pxi.dll file to C:\PCL\bin, replacing the previous one.
That's all. Now PixInsight should run fine on your vintage AMD or Pentium III computer
Sorry for the inconveniences.
Hola
Hemos detectado un problema que impide la ejecución de PixInsight 1.5.9 para Windows de 32 bits en viejos procesadores AMD e Intel.
Inadvertidamente, la biblioteca de soporte LCMS para versiones de Windows de PixInsight 1.5.9 fue compilada con soporte de instrucciones SSE2. Las instrucciones SSE2 no están soportadas por los siguientes procesadores:
- Procesadores AMD anteriores a Athlon 64, incluyendo todos los procesadores basados en Socket A.
- Procesadores Intel anteriores a Pentium 4.
Si tienes uno de estos procesadores, el subsistema de gestión del color de PixInsight, así como varios módulos de soporte de formato de archivo y de proceso, no funcionarán en tu computadora.
Si tienes un procesador más moderno, con soporte de SSE2, por favor ignora este mensaje.
La solución es muy sencilla. Por favor, sigue los pasos siguientes:
1. Si tienes PixInsight ejecutándose, termina su ejecución.
2. Descarga este archivo:
3. Descomprime el archivo zip. Esto generará un archivo lcms-pxi.dll.
4. Si has instalado PixInsight en su ubicación por defecto, entonces se encuentra en la carpeta C:\PCL. Ejecuta el Explorador de Windows y localiza la siguiente carpeta:
C:\PCL\bin
Si has instalado en una ubicación no estándar, cambia la carpeta a su ubicación correspondiente en tu carpeta de instalación personalizada.
5. Copia el nuevo archivo lcms-pxi.dll a C:\PCL\bin, reemplazando el anterior.
Eso es todo. Ahora PixInsight debería funcionar correctamente en tu antigua computadora basada en AMD o Pentium III
Perdón por las molestias.
