Author Topic: An Intriguing Way to Remove Light Pollution Gradients  (Read 10517 times)
Offline twade
« on: 2009 November 02 08:46:10 »
To all,
While reading the following article
http://www.space.com/scienceastronomy/091030-milky-way-panorama.html
about Axel Mellinger's 3000 frame Milky Way panoramic, I was intrigued by the following passage about his technique for removing light pollution gradients,
To fix this, Mellinger used data from the Pioneer 10 and 11 space probes. The data allowed him to distinguish star light from unwanted background light. He could then edit out the varying background light in each photograph and fit them together so that they wouldn't look patchy.
I don't know the technique he used to perform the transformations, but something similar in PixInsight Standard would be awesome.
Wade
Offline mmirot
Re: An Intriguing Way to Remove Light Pollution Gradients
« Reply #1 on: 2009 November 02 09:17:29 »
Even a overlay from the DSS images could be helpful to find points to use in a DBE model.
Max
Offline twade
« Reply #2 on: 2009 November 02 09:34:01 »
Max,
Although the DSS site is dark, it is not free from light pollution, especially at lower elevations; however, using the DSS images as a first guess would be helpful.  In order to achieve a "perfect" representation of reality, the technique Axel implemented is the way to go.  There is no light pollution in space.  :)
Wade
Offline twade
« Reply #3 on: 2009 November 02 12:12:47 »
To all,
Here's a better link:
http://home.arcor.de/axel.mellinger
It describes the process a little better; however, it gives no indication how he transformed the Pioneer data to a usable form.
Wade
« Reply #4 on: 2009 November 02 13:29:20 »
Max,
Wade
Yes, I do this for most nebula pictures these days. The biggest problem is that I first need to mosaic two or more DSS images together to get my field of view covered. But it helps quite a bit.
Offline twade
« Reply #5 on: 2009 November 02 13:53:42 »
To all,
I found the link that describes his technique in detail.  It is very interesting.
http://www.phy.cmich.edu/people/mellinger/research/Publications/2009/2009__PASP__Mellinger__A_Color_All-Sky_Panorama.pdf
Wade
Offline twade
« Reply #6 on: 2009 November 02 13:56:49 »
Sander,
I should start doing this myself, especially for those images taken from my backyard.  My regular site is probably darker than the DSS site so it may not help when imaging from there.  With my wide-field imaging, it's going to take a lot of DSS images to cover my FOVs.  :(
Wade
Offline twade
« Reply #7 on: 2009 November 02 14:11:09 »
Sander,
Using the "North America" light pollution map in Google Earth, the Apache Point Observatory is "covered" in light pollution.  I'm not so sure this is a good survey to mimic a dark sky from in order to remove local gradients caused by light pollution.
Wade
P.S. Here's a link to the kmz file: http://bbs.keyhole.com/ubb/ubbthreads.php?ubb=showthreaded&Number=269838&site_id=1#import
