Author Topic: Color moire in integrated image.  (Read 13428 times)
Offline lage
« on: 2020 March 01 14:07:13 »
Hi.
I'm having problem with color moire in the integrated image, see attachment.
Integrated from 266 images shot with a DSLR on two occasions. The two sets have a bit different alignment, which I assume is the cause of this color moire?
Is there a way of getting rid of this pattern? I have used BackgroundNeutralization and Colorcalibration on the attached image.
Any help is appreciated.
Best regards,
Lage
https://drive.google.com/file/d/1vT4qy4P5XU2ozaYQ5oaN6BGLELoDZjWT/view?usp=sharing
« Last Edit: 2020 March 01 22:54:13 by lage »
Offline lage
Re: Color moire in integrated image.
« Reply #1 on: 2020 March 01 14:11:05 »
For some reason it is impossible to add attchments. I have tried multiple times with different browsers. Anyone knows whats wrong?
Offline bulrichl
« Reply #2 on: 2020 March 02 02:55:32 »
Hi Lage,
in your integration I see vertical streaks and colored blotches. The blotches are not a moire pattern. In your image north is at the left side, so the vertical streaks are in east - west direction, i.e. in RA. The issues are definitely not caused by different alignment of the two sets. Presumably wrong / missing image calibration and not dithering are causing these artifacts. (The blotches have a large scale and will not be removed by dithering though.) However, some more information might help to classify the issue correctly:
- Which camera model did you use?
- Which exposure time was used for the subframes?
- Did you dither between subframes (presumably not or not sufficiently)?
- Did you calibrate the frames with a MasterDark and a MasterFlat?
If the answer to the last question is yes:
- How did you capture the dark frames? Presuamably the DSLR camera is not equipped with a cooling device. Were the dark frames captured at an ambient temperatures similar to the ambient temperature when the light frames were captured?
- How did you prepare the master calibration files and what were the settings for ImageCalibration?
Bernd
Offline dave_galera
    • QDigital Astro
« Reply #3 on: 2020 March 02 03:25:01 »
Looks like the forum is broken, I had the same problem.
Dave
« Reply #4 on: 2020 March 02 03:42:31 »
Hi Dave,
Yes, it's true. I'm going to investigate what has happened. Sorry for the inconvenience.
« Reply #5 on: 2020 March 02 07:25:56 »
It seems this is a known problem with the latest 2.0.17 security update of Simple Machines forum:
https://www.simplemachines.org/community/index.php?topic=571752.0
If somebody knows how to solve this problem, I'd appreciate any information. Right now I am unable to resolve this. Please use links to externally stored images for now. Sorry for the inconvenience.
Offline dave_galera
    • QDigital Astro
« Reply #6 on: 2020 March 02 08:16:12 »
Hi Juan,
I have joined the SiompleMachines forum to see if I can get a fix for the problem so leave it with me for now.
BTW the avitar's seem to have disappeared now as well
Dave
Offline dave_galera
    • QDigital Astro
« Reply #7 on: 2020 March 02 08:44:27 »
Attachment test
Dave
Offline dave_galera
    • QDigital Astro
« Reply #8 on: 2020 March 02 10:31:40 »
I ahve received the following responses to this attachment problem
you issue is -- with fair certainty -- the issue noted in the first response.
Your system is choking on memory...  if the mod didn't help, then I suggest checking with your host.
Yes the memory was indeed the problem in my forums...no idea how but it was trying to allocate waaaay too much ram and after I adjusted it from its enormous amount down to 1024 for each forum the members can attach images to their posts again.
try installing https://custom.simplemachines.org/mods/index.php?mod=4111 and see if it helps.
Dave
