Author Topic: Questions on XISF format  (Read 20566 times)
Offline ColinThomas
« on: 2020 February 29 09:19:20 »
To understand the XISF format a little better, I am looking at writing a python XISF parser.
I have a small RGB XISF file (from a preview) to test on.
I am having an issue with the XISF Block format, and was wondering what I have missed.
The parser can see:
   XISF signature 'XISF0100'
   Located the header length
   Identify the reserved location
   Extract the XISF XML header
   An then the series of zero byte blocks.
Both the end of the zero byte blocks,and the XML location:attachement value, point to byte
4096
But the 8 bytes at this location are as follows:
  INFO: XISF Signature located... :-)
  INFO: Header Length located: 1181
  INFO: XISF Reserved located... :-)
  INFO: Extract Image Data frm XML
   INFO: geometry  -> 555:483:3
   INFO: sampleFormat  -> Float32
   INFO: bounds  -> 0:1
   INFO: colorSpace  -> RGB
   INFO: location  -> attachment:4096:3216780
  INFO: Found end to Unused Space.... :-)
  DEBUG: Read from byte No: 4096   8  bytes...
  b'\xad\x8dL>\x12t\x1f>'
I have checked all 8 byte from 4096 till the end and can not locate XISB signature of 'XISB0100', (where
I can locate the initial XISF signature 'XISF0100') hence the confusion...
Both signature checks are made using the same python:
        self.infile = open(self.xisfFile, 'rb')
        while True:
           self.numChars = 8
            self.buf = self.infile.read(self.numChars)
            if (self.DEBUG):
                print("DEBUG: Read from byte No:", self.xisfByteLocation, " " , self.numChars , " bytes...")
I have double checked and the xisf is happily being read into pixinsight..
The spec I am looking at is :
https://pixinsight.com/doc/docs/XISF-1.0-spec/XISF-1.0-spec.html
Any pointers/help welcomed :-)
Clear skies
Colin
Offline ColinThomas
Re: Questions on XISF format
« Reply #1 on: 2020 February 29 13:00:03 »
An Update..
Just used linux/mac "strings" on a couple of .xisf files. And again the XISB0100 string does not seem to be present.
i.e.
strings Preview01.xisf | grep XIS
XISF0100
Extensible Image Serialization Format - XISF version 1.0
--><xisf version="1.0" xmlns="http://www.pixinsight.com/xisf" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.pixinsight.com/xisf http://pixinsight.com/xisf/xisf-1.0.xsd"><Image geometry="555:483:3" sampleFormat="Float32" bounds="0:1" colorSpace="RGB" location="attachment:4096:3216780"><Resolution horizontal="72" vertical="72" unit="inch"/><ICCProfile location="attachment:3223552:5964"/><Thumbnail geometry="400:348:3" sampleFormat="UInt8" colorSpace="RGB" location="attachment:3231744:417600"/></Image><Metadata><Property id="XISF:CreationTime" type="String">2020-02-27T14:29:20Z</Property><Property id="XISF:CreatorApplication" type="String">PixInsight 01.08.06.1457</Property><Property id="XISF:CreatorModule" type="String">XISF module version 01.00.09.0187</Property><Property id="XISF:CreatorOS" type="String">macOS</Property><Property id="XISF:BlockAlignmentSize" type="UInt16" value="4096"/><Property id="XISF:MaxInlineBlockSize" type="UInt16" value="3072"/></Metadata></xisf>
So my python code looks okay.
Has the XISB0100 Signature been removed or altered wrt the spec ?
many thanks again.
Colin
« Reply #2 on: 2020 March 02 03:18:41 »
Hi Colin,
In the first place, thank you for your interest in the XISF format.
Because the file you are working with is a monolithic XISF file. "XISB0100" is the signature of an XISF data blocks file, which, along with an XISF header file, is part of a distributed XISF unit. So you cannot find the "XISB0100" signature in this file.
Distributed XISF units are still not implemented in current versions of PixInsight, which can only work with monolithic XISF files. So unless somebody has implemented the distributed XISF model—which is something I seriously doubt—, there are no XISF data block files and hence no "XISB0100" signature exists out of the formal specification. Of course, support for distributed XISF units will be implemented in a future version of PixInsight, probably during the 1.9 version cycle.
Offline ColinThomas
« Reply #3 on: 2020 March 02 05:54:14 »
Hi Juan,
Many thanks for getting back" really appreciated:-)
I have reread the XISF-1.0 spec from:
Section 9.2 is Monolithic XISF File, which is what I always thought the Preview XISF
created from pixinsight was (which is what I'm parsing).
In Figure 8 "Structure of a monolithic XISF File" , after the XISF Header and Unused Space,
is the "Attached XISF data block". Both the end of the Unused space and the XISF Header,
point this to be byte 4096. So I am after the XISF data block format, and 2 sections further
it seems to be discussed.
Section 9.4 "XISF Data Blocks File", the goes onto talk about "An XISF data blocks file
shall have the following structure" :the Signature (A sequence of eight contiguous bytes
whose values must form the set 'XISB0100'). It state that block files can be local or remote.
Section 10.1"Attached XISF Data Block" has:
> An attached XISF data block is an XISF data block stored in a monolithic XISF file.
>The position of an attached data block from the beginning of the monolithic XISF file
>where it is stored, as well as its length in bytes, must be completely and unambiguously
>defined by the XISF header of the XISF unit.
>Attached XISF data blocks shall not occur in a distributed XISF unit.
So Attached XISF data blocks are in monolith and not distributed. The XISF data block
hyperlink does back to section 10
In the XISF header, the Image is described as:
<Image
 bounds="0:1"
 colorSpace="RGB"
So my file's location is attachment :-)
Section 10.3 has a bullet '"location="attachment:position:size"' and states "Defines an
attached XISF data block in a monolithic XISF file": which is what I have.
So, given that the monolith description states that I should have an attached XISF data
block (Figure 8), the description of the data block in 9.4 states that it should have the
XIFB0100 signature.
It looks like the spec on the website therefore has some ambiguity ;-)
Where else, apart from Section 10.1,should I get the format of  XISF data block used in a monolith XISF file ?
Do I just assume that a data block is described from Figure 9, from the start of the block index, (as the data block in this diagram states 'Position and length defined by a block index element, so needs the preamble from a block index) ?
=>an attached XISF block definition is Figure 9 (minus the XISB signature and 8 bytes reserved ??)
I hope my explanation above is useful, as a newbie reading the spec. I hope you can point
me to where I've slipped up ?
best regards
Colin Thomas
Offline ColinThomas
« Reply #4 on: 2020 March 02 13:23:29 »
Hi Juan,
Okay another read...
I'm more used to parsing microelectronics GDS binary files so this is new, please bare with me..:-)
<Image
 bounds="0:1"
 colorSpace="RGB"
So the Image data starts at 4096, and is 3216780 bytes long.
The image is 555x483 = 268065 pixels (on channel 3)
The image is RGB and Float32, so each pixel looked like
<32bits R/ 32bits G/32bits B> = 96 bits = 12 bytes
12 bytes x 268065 = 3216780 == attachment byte length :-)
the bounds state the range of values is from 0->1
The ICC data then starts after the Image data:
<ICCProfile
 ICC starts at byte 3223552 (the image data ended at 4096+3216780 = 3220876, so I expect some zero bytes.
Then there is a thumbnail
<Thumbnail
 colorSpace="RGB"
 Thumbnail starts at byte 3231774 (the ICC ended at 3223552+5964 = 3229516, so again expect some zero bytes
 There are 400x348 pixels = 139200 (on channel 3)
 The image is RGB and Uint8, so each pixel looks like
 <8bits R/8bits G/8bits B> = 24 bits = 3 bytes
 3bytes x 139200 = 417600 == attachment byte length :-)
 One question: if the geometry is width:height:channel, are pixels being stored as row by row,
 i.e
 height0/width0, height0,width1, height0,width2 ....height0,widthN
 heigthN/width0 ....................................heightN,widthN
 where we start at the bottom left pixel, row after row to finish at top right pixel
 So everything is specified from the header file, no need for an index section.
If this is it, then I can start coding again..
Many thanks
Colin
