Author Topic: Subframe Selector - What am I looking at?  (Read 7563 times)
Offline UlteriorModem
« on: 2020 February 16 06:13:56 »
When using the subframe selector script and looking at the plots, I am often confused as to what am I looking at exactly?
It seems that in some plots the higher numbers are worse (FHWM) that's fairly obvious. But when looking at other aspects lower numbers are worse?
Is there a definitive guide anywhere that explains all of the aspects and how to best choose which to keep and which to toss?
Thanks.
Offline John_Gill
Re: Subframe Selector - What am I looking at?
« Reply #1 on: 2020 February 16 10:09:55 »
Basically you want the highest SNR and the lowest Eccentricity and or FWHM. With Ecc and FWHM, scores lower than 0.4 is not detectable by eye. I use a formula to weight each frame, calculating the result based on 50% SNR and 25. % Ecc and 25% FWHM.
space is not not black
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
« Reply #2 on: 2020 February 16 13:13:24 »
Thankyou John,
I will have to admit that pixel math is not my strong suit. What would that formula look like?
Offline John_Gill
« Reply #3 on: 2020 February 16 22:34:18 »
Here is the formula I use:
(15*(1-(FWHM-FWHMMin)/(FWHMMax-FWHMMin)) + 15*(1-(Eccentricity-EccentricityMin)/(EccentricityMax-EccentricityMin)) + 20*(SNRWeight-SNRWeightMin)/(SNRWeightMax-SNRWeightMin))
So I use this formula to "weight" each frame and make a note of the best image name.  In SFS you can then sort on "weight".....Output the frames to an "Approved" folder.  This will write the weighting to the "FITS header" with a name SSWEIGHT.  When doing StarAlignment, use the best frame from SFS.  Then in ImageIntegration under "weights" select "FITS Keyword" and type in SSWEIGHT.
This will create you new image using the highest weighted image contributing the most going down to the least weighted image contributing the least.
space is not black
John
« Reply #4 on: 2020 February 17 16:33:13 »
Thank you very much John for taking the time to type all that out :D
I will give it a try!
Offline John_Gill
« Reply #5 on: 2020 February 17 22:05:16 »
No problem.  Copy and paste works great  :smiley:
Offline dave_galera
    • QDigital Astro
« Reply #6 on: 2020 February 18 02:15:54 »
Thanks for the formula John, I will also give it a try.
Dave
« Reply #7 on: 2020 February 18 09:23:41 »
I copy pasted the formula into my version of PI and it was 'invalid'. I checked the syntax twice and it seems like it would be okay but PI did not think so.
Something about SNRWeightmin not being valid.
Offline John_Gill
« Reply #8 on: 2020 February 18 10:00:20 »
Here is the formula again, please double check that there are two ) at the end of the formula.
John
« Reply #9 on: 2020 February 18 13:50:48 »
Thanks but that still did not work. I got it to work though.
It seems that FHWMMin and such have to be fully spelled out as FHWMMinimum. After I corrected all the abbreviated versions it started working.
Thanks!
« Reply #10 on: 2020 February 18 14:25:12 »
i think the keywords for the subframe selector script are different from the subframe selector process. could that be the problem?
« Reply #11 on: 2020 February 20 13:13:17 »
I did not even know there was a subframe selector process. So I went and looked at it and did not see where a formula could be plugged in to it?
So to answer your question, I don't know.
« Reply #12 on: 2020 February 20 13:19:26 »
well the SFS process has multiple windows. one of them has a weighting expression and the other a acceptance/rejection expression if i remember correctly.
Offline John_Gill
« Reply #13 on: 2020 February 20 22:39:29 »
Remember this is for the SubFrameSelector Process and not the Script.
When you load the SFS, it should open three windows, first - SubFrameSelector window, second - Measurements window and thirdly the Expressions window.  If the second and third window do not open, then in the SubFrameSelector window, click the two buttons in the top right corner (Fx & Graphs) and that should open the "missing" windows.
In the "Expressions" window under Weighting, is where you input the formula:   (15*(1-(FWHM-FWHMMin)/(FWHMMax-FWHMMin)) + 15*(1-(Eccentricity-EccentricityMin)/(EccentricityMax-EccentricityMin)) + 20*(SNRWeight-SNRWeightMin)/(SNRWeightMax-SNRWeightMin))
The "graphs and results" window will allow you to view the results.  When you are happy with your file selection, go back to the main window under "Routine" select "Output Subframes" and in the "Output Files" put in the folder location (I call my folder, "approved") and in the "Keyword" type in SSWEIGHT.
The SSWEIGHT keyword will be embedded into the image and will be used when doing an ImageIntegration and using the keyword SSWEIGHT.
space is not black
John
« Reply #14 on: 2020 February 21 13:57:21 »
This will work in the script...
(15*(1-(FWHM-FWHMMinimum)/(FWHMMaximum-FWHMMinimum)) + 15*(1-(Eccentricity-EccentricityMinimum)/(EccentricityMaximum-EccentricityMinimum)) + 20*(SNRWeight-SNRWeightMinimum)/(SNRWeightMaximum-SNRWeightMinimum))
All I did was spell out the imum's.
