Something wrong goes with LRGBCombination (or, as often happened, this is a feature that I don't know how to use correctly
Anyway - below is a screenshot from PI1.5.6 with initial crops of L, R, G, B channels (archive of 8 bits FITS will try to attache to the next message) and LRGB result, stretched with STF Auto Stretch individually. LRGBCombination was used with default parametes.
For some reason you can see that M31 core is YELLOW that means that B channel is equal to 0 inside it on LRGB. It's obvious that initial B shot has some signal in the M31 core (see marks on screenshot, reading of channel values is available in Status Bar).
What's going wrong? Level of signals in different initial channels is seriously differ. Should I change some parameters from their default value?
8 bits crops are used for illustration purpose only here, nonetheleas result is the same with 16 bit integer of 32 bit float.
