Author Topic: Is Drizzle worth doing? Also De-convolution on NB data?  (Read 5198 times)
Offline jlodge
« on: 2020 February 15 06:45:18 »
Dithered NB data taken with a Takahashi FSQ-106ED and an ZWO ASI1600MM-Pro (1.48"/pixel), is it worth using drizzle? The reason that I ask is that MURE does not work with drizzled data and I like the results that MURE gives.
What are people's thoughts on the benefit of De-convolution of NB data?
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
Re: Is Drizzle worth doing? Also De-convolution on NB data?
« Reply #1 on: 2020 February 15 20:14:38 »
I would definitely take a look at a side by side of using drizzle and not.  It really depends on how good your stars are and your seeing.  It seems that you are well sampled already so you may not see much improvement, but you should check.  I know that with my system, where my resolution is sub 1 arcsec, it makes no sense to use drizzle.
As to deconvolution, it depends on what you intend to use as your luminance frame.  If you are using your Ha master or create a monochrome synlum to combine with your color data, it always helps to add a bit of extra resolution and tightens up the stars.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline jlodge
« Reply #2 on: 2020 February 16 03:37:30 »
Thank you very much Jim.
Offline Terry Danks
« Reply #3 on: 2020 February 17 19:13:44 »
I'm very new to drizzle. That said, I do a lot of imaging with an FSQ106EDXIII and the 0.73 QE reducer on a FF STL11002 camera. That gives me a plate scale of 4.86 a-s/px. Drizzle definitely improves the smaller stars, making them round rather than square. You might not notice it at typical web scales but pixel-peeping shows a real improvement.
