Hi PI Team,
PI 1.5.6 + Win XP Prof SP3
When any modal dialog is shown in PI (examples are Select [Channel] Source Image called from LRGBCombination or STF Auto Stretch dialog from STF) the PI's main menu turns in "inactive" grey state (see screenshot, the main menu will remain the same after dialog will be closed).
The issue is - main menu doesn't redraw to expected "active" black (color) state when modal dialog will be closed. Will redraw correctly after mouse will be moved above it (on something like OnMouseAbove trigger or what is the correct name in Win API
Could you please fix this minor issue and trigger main menu update on close of Modal Dialogs?
PI Team, thanks a lot again for your impressive work!
Yuriy
