Author Topic: WeightedBatchPreprocessing programming warning on undeclared variable.  (Read 5263 times)
Offline jcinpv
Warning [156]: /Applications/PixInsight/src/scripts/WeightedBatchPreprocessing/WeigthedBatchPreprocessing-engine.js, line 2035: assignment to undeclared variable images
Got this warning right after completing best reference frame for registration.
As a long time build engineer, I never let warnings get by me. This type of programming mistake can lead to disaster.
I had just updated all patches prior to running PI. Running version 1.8.8-4 Ripley (x64) on a Mac with Catalina 10.15.3
John C.
Paulden, AZ
Offline dave_galera
    • QDigital Astro
Ummmm, looking at the code the array 'images' gets defined on line 2087 after it has been used on line 2035.......
Dave
Offline robyx
Hi jcinpv,
thanks for reporting this error. Actually it's pretty difficult to reproduce it without any further information, it would be very useful if you could share the log file generated into the "logs" output subfolder. Moreover, it would very helpful if you could share more infos (the more the better) about the session that run into the problem (which frames and settings for each image type).
With your support I'm definitely willing to investigate further.
Kind regards,
Robyx
