Author Topic: Help with Tri-band filter process flow  (Read 1074 times)
Offline JST200
« on: 2020 February 10 07:22:11 »
I have a process flow that I thinks works well enough. However, when processing images taken with a Tri-band filter the results tend to be very red biased.
I know another astro processing app has a "in built" process for handling Trib-band filters. People who use it seem to create a final image that has a more balance colour distribution. I think I have found a way to emulate this process in PI, but I am unsure where in the process flow it should go.
Starting with an integrated OSC image my current process flow is:
  • Dynamic Crop
  • PCC (broadband)
  • Histogram Transformation
  • TBVDenoise
  • HDR Multiscale Transform
  • Starnet++ (produce a "no stars" and a "stars only" images)
  • Curves TRansformation (of "no stars" image)
  • Morphological Transform (of "stars only" image)
  • Pixelmath (to combine "no stars" and "stars only" images - iif((stars only<=0.01),stars only,0.001); ~(~no stars*~stars only)
  • SCNR
  • Local Histogram Equalisation
Now I think the following PI process emulates the other apps Tri-band specific process:
  • Channel Extraction (red to "rHa", green to "gHbetaOiii" + ", blue to "bHbetaOiii"
  • PixelMath:
    • untick "Use a single RGB/K expression"
    • tick "Create new image"
    • R/K expression: rHa*1.00 + gHbetaOiii*0.00 + bHbetaOiii*0.00
    •    G expression: rHa*0.20 + gHbetaOiii*0.80 + bHbetaOiii*0.80
    •    R expression: rHa*0.15 + gHbetaOiii*0.85 + bHbetaOiii*0.85
So, my questions are:
  • Is my standard process OK?
  • Does my pixelmath do what I want it to do (see attached image to see what the pixelmath is trying to replicate)?
  • Where in my process flow should I add the extra Tri-band steps
I hope that all makes sense.
Any and all comments and suggestion for any improvements gratefully received.
Thanks for any help anyone can give!!
Cheers, Jim
« Last Edit: 2020 February 11 00:46:53 by JST200 »
