Author Topic: More Help Needed with Mosaic  (Read 4094 times)
Offline Robert Q. Kimball
« on: 2020 February 05 10:45:52 »
I am in the process of putting together a six panel mosiac of the Witch's Head Nebula.  I have a synthetic star field that is the right size for my mosaic.  I am able to register all of my panels with the sythetic star field, but when I use the GradientMergeMosaic process i am getting double star images in several of the overlap areas.
What I think I need is for the Registration process to work harder to distort my images to align with the non-deformed synthetic star field.  I've tried everything I can think of to no avail.
I'm attaching a screen shot of one of the seams.  Some of the seams are perfect, but there are always several with double stars.
Any advice would be welcome.
« Last Edit: 2020 February 05 11:07:47 by Robert Q. Kimball »
Re: More Help Needed with Mosaic
« Reply #1 on: 2020 February 05 11:31:23 »
try using MosaicByCoordinates to generate the registered panels. it's designed to undo these distortions.
« Reply #2 on: 2020 February 06 15:26:05 »
Thank you for the tip!  Probably 90% of my problems were eliminated.  I'll probably play around with the various combining strategies and clamping to see if I can do better.  This is about the third or fourth time you've helped me.  Thanks
« Reply #3 on: 2020 February 06 16:07:34 »
that is great to hear, glad i could help!
