Author Topic: Weighted Batch Processing - No filter  (Read 5797 times)
Offline Phillip Klein
« on: 2020 February 02 22:23:22 »
Hello,
Recently I tried using Weighted Batch Processing but have not been successfully registering light frames. The Smart Report shows:
Filter_Sulfer.xisf
Calibration completed
Frames analysis completed
Referenced fram for registration D:/file name
Weights successfully computed and stored
Group of 4 light frames
Binning:1
NoFilter
Exposure: 900.00s
!!!Error: Star alignment failed to register 3 images out of 4. A minimum of 3 images must be successfully registered.
The group of 4 light frames subs taken with a Hydrogen alpha filter. The file naming of the sulfer frames is the same as the hydrogen so I am confused by the NoFilter text.
Equipment I am using to capture the subs is the following: AP Mach 1 GTO mount, Celestron 8" Edge, AP 0.67 focal reducer, QSI 532ws 5 position filter wheel. Orion Starshooter autoguider
Light subs were sulfer 480 sec x 5, oxygen 480 sec x 5, hydrogen 900 sec x 5
I received the same message when I ran WBPP with all the narrow band filters exposures being 480 seconds.  I question if length of file name can cause problems.
Would appreciate any help in fixing whatever I am doing wrong. It is frustrating not to be able to integrate all the lights, darks, flats and bias frames.
Attached is a copy of the Smart Report.
Thanks again,
Phil
Offline dave_galera
    • QDigital Astro
Re: Weighted Batch Processing - No filter
« Reply #1 on: 2020 February 03 01:38:08 »
Think you need to post the images before anybody can help you
Dave
« Reply #2 on: 2020 February 03 08:19:11 »
Hi Dave,
That is the problem. I cannot acquire an image. The WBPP provides a Master Flat, Master Dark and Master Bias but no other images. I will gladly attach one of the H subs if that helps.
Thank you,
Phil
