Author Topic: Problem with Mosaic  (Read 3929 times)
Offline Robert Q. Kimball
Problem with Mosaic
« on: 2020 January 30 11:07:05 »
I have done more then 10 mosaics using PixInsight with great success.  Suddenly I can no longer make a mosaic.    I am attaching the result of the GradientMergeMosaic.  The overlapping areas appear to be the sum of both images.  (1) Is there something I'm missing with the Registation Process?  (2) Is there something I'm missing with the GradientMergeMosaic Process?  Any help is welcome.
Offline dave_galera
    • QDigital Astro
Re: Problem with Mosaic
« Reply #1 on: 2020 January 30 11:59:09 »
Without knowing your process it is difficult to suggest anything and if you are doing the same as you have for the last 10 mosaics then would assume it should still work. I have noticed that the overlap areas are a bit small, I normally use a 10% overlap to the the software a fighting chance.
I originally developed my process from this video, maybe helpful:
https://www.youtube.com/watch?v=H2r3ZYqCaP8
Dave
« Reply #2 on: 2020 January 30 12:56:35 »
Thank you for responding.  Are you saying the GradientMergeMosaic Process needs more overlate.  I did the registration on a synthetic star field.
Bob
Offline 1DegreeN
« Reply #3 on: 2020 January 30 18:19:08 »
I've just recently begun to use GradientMergeMosaic and I found the "overlay" option instead of "average" for the combination type was much better. I don't know if "average" worked better in previous versions but perhaps you could check out "overlay".
Offline dave_galera
    • QDigital Astro
« Reply #4 on: 2020 January 31 05:58:09 »
Bob
10% overlap minimum is recommended
Dave
