Author Topic: Difficulty in installing updates to Ver 1.8.8.3  (Read 17183 times)
Offline steve banbury
« on: 2020 January 23 22:25:24 »
Hello--I expect I am doing something incorrectly, but eveery time I try to install updates for Ver 1.8.8-3 I get an error message.
I have uninstalled, and then reinstalled PixInsight multiple times with the same result.
Can someone tell me where i'm going wrong?  Attached below is the error message which results:
[2020-01-24 06:17:20] Begin updater1
[2020-01-24 06:17:20] *******************************************************************************
[2020-01-24 06:17:20] This is PixInsight Updater stage one program version 01.00.12
[2020-01-24 06:17:20] Core application PID         : 19872
[2020-01-24 06:17:20] Target application directory : C:/Program Files/PixInsight
[2020-01-24 06:17:20] Source update directory      : C:/Users/steve/AppData/Local/Temp/PixInsight64-update/contents
[2020-01-24 06:17:20] Waiting for the PixInsight Core application to terminate...
[2020-01-24 06:17:22] PixInsight Core application terminated.
[2020-01-24 06:17:22] Waiting for things to stabilize...
[2020-01-24 06:17:24] Begin update process.
[2020-01-24 06:17:24] Source updates database loaded: C:/Users/steve/AppData/Local/Temp/PixInsight64-update/contents/updates.xri
[2020-01-24 06:17:24] File removed: C:/Users/steve/AppData/Local/Temp/PixInsight64-update/contents/updates.xri
[2020-01-24 06:17:24] Begin file removal process.
[2020-01-24 06:17:24] File removed: C:/Users/steve/AppData/Local/Temp/PixInsight64-update/contents/remove.lst
[2020-01-24 06:17:24] Begin file transfer process.
[2020-01-24 06:17:24] *** Error: Unable to create file: Win32 error (32): The process cannot access the file because it is being used by another process.
: C:/Program Files/PixInsight/bin/PixInsight.exe
[2020-01-24 06:17:24] End updater1: ERROR
Offline BillM
Re: Difficulty in installing updates to Ver 1.8.8.3
« Reply #1 on: 2020 January 26 14:43:41 »
This is exactly the same error I get:
https://pixinsight.com/forum/index.php?topic=14565.0
« Reply #2 on: 2020 February 02 09:35:17 »
Thanks for your link Bill.   Next time I am home I will try installing the updates piecemeal and
skip the update PixInsight Core v1.8.8-4 (update/bugfix).
I am running 64 bit Win10, so the reference to Win32 error seems odd, but I am not a computer whiz.
« Reply #3 on: 2020 February 25 21:31:34 »
Hi Bill--well, I got home today, and tried installing piecemeal.  All was successful except for the PixInsight Core v1.8.8-4 (update/bugfix).
I have tried everything I could think of with NO success on that update.
I am surprised none of the moderators has provided any suggestions.
I give up!
Offline dave_galera
    • QDigital Astro
« Reply #4 on: 2020 February 26 04:11:00 »
To me this looks like a Windoooze problem not a PI problem. Some process is accessing the same file that PI wants to write, this problem has been noted before.
Dave
Offline dpastern
« Reply #5 on: 2020 March 02 04:51:02 »
Have you tried turning off all anti-malware software and all AV software?
Have you tried running the update in selective safe mode (safe mode with network enabled)?
Just 2 thoughts that come to mind.
I'm running Windows 10 x64 and had a few odd errors the other night when trying to update (not the same as you I think).  A few nights later, the update worked without issue.  Weird...I didn't change anything on the computer at all.
Offline dave_galera
    • QDigital Astro
« Reply #6 on: 2020 March 02 07:21:21 »
Why not update to version 1.8.8-5 and give that a whirl.
Dave
« Reply #7 on: 2020 March 02 10:42:52 »
I did update to 1.8.8-5 over the weekend, and all went perfectly.
I consider the issue closed.
Thanks for your suggestion!
Offline dave_galera
    • QDigital Astro
« Reply #8 on: 2020 March 02 11:41:30 »
Glad it worked out for you Steve
Dave
