Author Topic: Horsehead and Flame Nebula Artifact?  (Read 12715 times)
Offline greg.dulaney
« on: 2020 January 23 17:59:55 »
I have a greenish 3 pointed "artifact" I think, see circled area in attachment.  I'm a Pixinsight novice so I don't know if I've introduced something here.  When I review others work with this object I don't see this structure.  I imaged the Rosette Nebula earlier in the evening with the same setup as below, CCD untouched.  There is no "artifact" in the Rosette.
Taken with a RASA 8, QHY12, 24 x 300 sec subs, PHD2 guiding, Pixinsight Batch Preprocessing and post-processing.
Re: Horsehead and Flame Nebula Artifact?
« Reply #1 on: 2020 January 23 19:28:02 »
that's a schmidt ghost... happens with bright stars (like alnitak) and certain types of reflecting telescopes...
« Reply #2 on: 2020 January 24 04:24:36 »
Thanks!  Am I stuck with it or is there a method to process it out?
Offline John_Gill
« Reply #3 on: 2020 January 29 06:25:46 »
I have the same issue with a Celestron 8"EdgeHD.
You can try and create a mask over the strange reflection, invert the mask and adjust the color and brightness.
Good luck
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
