Author Topic: CR3 RAW Data issue  (Read 1059 times)
Offline frasax
CR3 RAW Data issue
« on: 2020 January 23 10:25:05 »
i´m testing the new Canon EOS Ra and run into Problems, using the BatchPreprocessingScript.
The other Day i had no Problems, but today i get two strange errormessages and behaviors (updatet 3 updates yesterday, so i think it might be a bug).
First Errror Message: No Convergence or in RMS Noise Evaluation routine using k-sigma routine
2n error Message: zero or insignificant Signal detected (empty image?)
And yes, the Image Files seem to be heavily corrupted.
Any Ideas anyone?
Thanks in advance.
CS Frank
Re: CR3 RAW Data issue
« Reply #1 on: 2020 January 23 11:30:23 »
this is probably a calibration problem - did you recreat the master dark/bias or are you using older ones?
Offline frasax
« Reply #2 on: 2020 January 23 11:48:16 »
Hi Rob,
first i´ve tried one i´ve created before. After the First Fail i´ve started from the Top and created a new Masterbias in the Process.
CS Frank
« Reply #3 on: 2020 January 23 12:07:26 »
and that is failing too? or it resolved the problem?
Offline frasax
« Reply #4 on: 2020 January 23 12:24:18 »
that is failing too, yes.
