Author Topic: Hwo to delete control panel of previous sequence settings?  (Read 911 times)
Offline ballyhoo
Scenario:
#1 I have created a specific set of settings  re gain, and temp in my equipment profile, which I saved 2) created new sequence "with profile" selecting profile from #1. I decide to go to control panel and ad hoc change settings for that sequence. 3) Later, I create a new sequence, by loading with same profile, #1.
However that sequence retains the settings that were changed in the control panel, instead of using the settings defined in the equipment profile which was loaded in the sequence. How can I avoid this, or, as a matter of course, do  users always have to both load a new sequence with the specific equipment profile, and check the control panel?
Another question:
I have found it easier to create a separate equipment profile for the same exact equipment but with different gain settings. Is there a better way to have more than one gain setting in an equipment profile, and when creating a new sequence, have the specific gain that is wanted?  How are people doing that?
Thank you!
Re: Hwo to delete control panel of previous sequence settings?
« Reply #1 on: 2020 January 20 13:51:03 »
?? this belongs in the SGP forum?
