Author Topic: Help with a bad pixel/column on STL-11000M  (Read 1060 times)
Offline logieberra
« on: 2020 January 20 01:47:59 »
I have a very stubborn bad column at the bottom right of my chip. See attached.
After running the batch-pre-processing script it is the only defect that remains. I just can't seem to get rid of it in PI.
A colleague put me on to CCDStack2 which works and does remove it via their "repair bad pixels/columns" tool, but I already own a copy of PI and would prefer to give it a good go before making the jump.
The data is available at this Dropbox link:  https://www.dropbox.com/sh/hdbzk198tzwnz17/AAD7tY44r30z5x1B7l96wKtQa?dl=0
I would be most grateful if someone would give this a crack and confirm what tool I might use in PI and recommended settings.
A big thank you in advance to that very kind person!
Logie
Offline Geoff
Re: Help with a bad pixel/column on STL-11000M
« Reply #1 on: 2020 January 20 03:25:38 »
Use the pattern subtraction scripts in the latest PixInsight version
https://pixinsight.com/forum/index.php?topic=14484.msg86743#msg86743
Don't panic! (Douglas Adams)
Offline aworonow
    • Faint Light Photography
« Reply #2 on: 2020 January 20 07:01:00 »
Use cosmeticCorrection on linear images after calibration.
Offline Geoff
« Reply #3 on: 2020 January 20 11:39:45 »
See the third post here https://pixinsight.com/forum/index.php?topic=13954.msg84033#msg84033 for reasons why it may be better not to use cosmetic correction
