Author Topic: [Unofficial] New Module: QuickSTF  (Read 8158 times)
« on: 2009 October 03 23:38:57 »
Hello
Here is a new pre-release: QuickSTF. As the name suggest, it is intended to provide with an easy and fast way to adjust the SFT of any image. It is not as "accurate" as the current STF process, specially if you want to translate those values into a Histogram Transformation, but I think that it is very intuitive, and the dynamic readout mode allows for a very quick way to inspect the image (try at full view).
So, here are two main parameters: brightness and contrast. Yes, that straightforward. But, those operations have been designed in terms of histogram transformations, so they do not behave exactly as common brightness and contrast adjustments... so they reflect that behavior, but is not the same :P A third parameter allows to modify the dynamic range, extending it. If you have problems adjusting the brightness/contrast for features very close to the black or white points, try this.
And, at the right, you'll see the jewel of this process, the readout mode activation. When enabled, clicking on the image will automatically change the brighness and contrast, depending on the coordinates. Just play :)
So, here are the files (Win32):
http://pteam.pixinsight.com/carlos/modules/QuickSTF-pxm.zip
http://pteam.pixinsight.com/carlos/modules/QuickSTF-src-2009-10-03.zip
I hope you'll like it!
Re: [Unofficial] New Module: QuickSTF
« Reply #1 on: 2009 October 04 06:56:55 »
wow
Offline Yuriy Toropin
« Reply #2 on: 2009 October 06 13:09:50 »
Downloaded and tried it...
it's VERY COOL, especially in activated readout mode when you can instantly control image appearence with the mouse. Really like it!  :)
« Reply #3 on: 2009 October 06 15:40:21 »
Thank you very much :)
Offline papaf
« Reply #4 on: 2009 October 06 23:01:04 »
Hey guys,
sorry to ask maybe an obvious question, but how is a poor linux user like me supposed to use all those cool modules? I tried compiling them to no avail. There's always something that doesn't fit. Should I post the errors here, or are those modules created against a newer PCL release?
Thanks!
Fabio
« Reply #5 on: 2009 October 07 04:31:20 »
Hi Fabio
Hmmm, I'll try compiling them with ubuntu this weekend.
Anyway, as soon Juan finishes his current tasks, he'll take these modules, pulish them, and include in the 1.5.8 release. So, one way or another, soon you'll have them for linux ;)
Offline Harry page
« Reply #6 on: 2009 October 07 10:44:22 »
Look forward to the 64 bit version as well  ;D
Harry
Harry Page
