Author Topic: ChannelCombination: Invalid source color space  (Read 669 times)
Offline mlamb1
« on: 2020 January 10 10:13:13 »
I am trying to make a different HaRGB mix and get the error:
I have used the same data on prior CC mixes, using 90%/10% HaR, and 60%/40% HaR.  This time I was trying a 30%/70% HaR mix.  I used PixelMath prior to mix the Ha and R, as I did previously to get the HaR blend which was mapped to R in CC.
All of the underlying sources, Ha, R, G, B were cropped to the same dimensions.
What is causing the error?
Offline oldwexi
    • Astronomy Pages G.W.
Re: ChannelCombination: Invalid source color space
« Reply #1 on: 2020 January 10 12:19:51 »
One of the 3 views for ChannelCombination has been RGB and not Gray.
Channel Combination wants mono images (gray) and not color (RGB) images as input.
Check on the head-bar of each of the 3 images if there is Gray or RGB mentioned.
Gerald
Offline mlamb1
« Reply #2 on: 2020 January 10 14:12:40 »
Thanks!  That was it, though I do not know how it happened.
I created my HaR30 exactly like it created HaR60, & HaR90.  I even used a new instance of the PixMath (w/ changing ratios and output name).
I change it to Grey by using the CIE Lum button.  Is that the best way?
