Author Topic: Integration of different camera angle frames and scope lenght  (Read 858 times)
Offline eisenheim89
Hi all,
The situation is:
-same camera
-A: Light frames with camera with an X angle (200/800 SCOPE)
-B: Light frames with camera with an Y angle (200/800 SCOPE)
-C: Light frame with camera with same x angle but with a wider scope (343mm).
Is it possible integrate all the frames without losing resolution (the non common area in image integration)?
1) I would like to integrate the A frames with the B to gain resolution and details (without losing the missing frame for one of this)
2) I would like to add to the C (WIDER) frame the details of the nebula of the A or B frames.
I tried to play with the GradientMergeMosaic but the result is poor details due to the average method i think
I also tried to play with processing all the frames togheter after a staralignement but the result is visible edge (in attachement)
Any advice?
« Last Edit: 2020 January 06 11:17:49 by eisenheim89 »
Re: Integration of different camera angle frames and scope lenght
« Reply #1 on: 2020 January 06 13:20:42 »
i suppose that in order to prevent the problem with GradientMergeMosaic you could "black out" the area in the wider field image that corresponds to the narrow-field image. to do this, i think it might be easiest to make a copy of the narrow image which has been registered to the wide image, and then apply the pixelmath iif($T>0,1,0). that should create a mask where all the pixels that have data in the narrow image are set to 1. then mask the wide image with that mask and apply the pixelmath 0 to the wide image. save that as a new file, and then run GMM on the 'blacked out' wide image and the original narrow field image which was registered to the wide image.
if you get artifacts you could experiment with removing some wavelet layers from the mask to smooth the edges a little bit, or maybe use morphological transformation to shrink the mask down so that you still have some overlap between the two images when running GMM.
