Author Topic: Sun  (Read 4619 times)
Offline shold
    • http://www.flickr.com/photos/siegi252
Sun
« on: 2009 September 28 12:51:19 »
i need a suggestion for my high resolution sun image.its a gray Image.
I would like to increase the contrast for the granulation, but not for Umbra/ Penumbra.
the mask tool is active, but only for RGB. Is there a way, a mask for a gray image to make?
regards
Siegfried
Re: Sun
« Reply #1 on: 2009 September 28 14:37:57 »
It doesn't matter if the image is grayscale or color, the mask system works just the same. You only have to use another grayscale image as the mask.
So, if you want to increase the contrast of the granulations, you may try ATrousWavelets, to perform local contrast enhancements, instead of a global one throught Curves.
