Author Topic: help with CFA image calibration/registration/integration and MureDenoise  (Read 760 times)
Offline Buzz
    • The Astrophotography Manual - support
I have been following the advice on the forum and carefully avoiding the pitfalls of CMOS sensor dark frame subtraction during calibration and have had some respectable results. In my process, I debayer the image prior to registration which is then followed by integration.
I have had spectacular results with Mure Denoise with my mono CCD in the past and wondered how to use that with a CFA image. I'm guessing the debayering process messes the noise evaluation and I cannot use it... or maybe I should not debayer until after registration/integration/MureDenoise ?
regards
Chris
Offline mschuster
Chris, I am sorry you are correct, MureDenoise does not work with CFA images (nor drizzle images for the same reason).
