Author Topic: PMCC Error (Bug?) - *** Error: Unable to acquire valid coordinate information***  (Read 4058 times)
Offline jwaters125
I am getting an error during Online Coordinate Search.  I have tried changing the Database Server.  I am using PI 1.8.8-3.
I used WBPP for the initial processing.
BTW - clearing / resetting PMCC does not clear the error on the screen.
http://simbad.u-strasbg.fr/simbad/sim-tap/sync?request=doQuery&lang=adql&format=TSV&query=SELECT oid, ra, dec, pmra, pmdec, plx_value, rvz_radvel, main_id, otype_txt, sp_type, flux FROM basic JOIN ident ON ident.oidref = oid LEFT OUTER JOIN flux ON flux.oidref = oid AND flux.filter = 'V' WHERE id = 'M31';
21662 bytes downloaded @ 27.1 KiB/s
*** Error: Unable to acquire valid coordinate information.
« Last Edit: 2019 December 16 22:40:27 by jwaters125 »
Hi Jim,
This has been a temporary issue with Simbad database servers, which has already been solved today. The Online Coordinate Search dialog of the PhotometricColorCalibration tool works normally now.
Please note that we have not created this problem. The online search functionality depends on the availability of online database services.
Offline jwaters125
Thanks Juan
Offline gilbertonp
Hi, I am still experiencing the same issue since a few days:
 but it works with imagesolver which doesn't use the same server
is it coming from Simbad site server?
best regards
Philippe
