Author Topic: api-ms-win-core-libraryloader-l1-2-2.dll missing  (Read 1086 times)
Offline Frank
« on: 2019 December 14 09:05:12 »
Just downloaded and attempted to install 1.8.8.3 for windows x64 and got this error when launching the program "api-ms-win-core-libraryloader-l1-2-2.dll missing" gives the message 3 times then Pixinsight opens. 1.8.8.2 does not have this error. Is there a way to fix this ? Thanks.........
Update ... PixInsight 1.8.8 installs and works just fine. After all updates version shows 1.8.8.2 and no missing dll error message. Research indicates that this should be provided by the install software. Could it possibly be left out of the version ?
Win 7 64 bit.
« Last Edit: 2019 December 14 10:05:28 by Frank »
Offline SdA
Re: api-ms-win-core-libraryloader-l1-2-2.dll missing
« Reply #1 on: 2019 December 14 09:32:58 »
Win 7  x64
Problem solved. I found   api-ms-win-core-libraryloader-l1-2-0.dll (32-Bit)    and copied it to PixInsight Bin.
Offline tloebl
« Reply #2 on: 2019 December 14 10:56:58 »
Where did you find the file?
Offline SdA
« Reply #3 on: 2019 December 14 11:25:47 »
<* link removed *>
<* link removed *>
EDITED BY THE FORUM ADMINISTRATOR
Links removed because they pointed to unverified sources providing copies of Windows system files. Be aware that system files can only be obtained securely from the original operating system provider (Microsoft Corporation in this case). Downloading them from other sources online is extremely dangerous because of the potential risk of acquiring malwares.
« Last Edit: 2019 December 14 12:11:22 by Pleiades »
« Reply #4 on: 2019 December 14 11:44:20 »
This problem has nothing to do with PixInsight. The file you are referring to is a system component that should be provided by any clean and reasonably updated Windows installation, at least since 2015.
Not at all. As noted, this file is a system component, so it should be provided by your operating system. These critical components must be kept up-to-date and synchronized with the rest of the system, and this is the sole responsibility of the operating system.
Besides this, please note that Windows 7 and Windows 8 are not supported by current versions of PixInsight. The only Windows version supported by PixInsight is Windows 10.
Offline tloebl
« Reply #5 on: 2019 December 14 12:02:39 »
Kind of wish I knew that before installing in Windows 7...
Offline jbadal
« Reply #6 on: 2019 December 14 12:32:33 »
I reviewed my PI update email re: PixInsight 1.8.8-3 Ripley Released .
If in this email, There had been an easily identifiable comment, that " NOTE- THIS RELEASE IS ONLY FOR WINDOWS 10 !"-
Would have saved me a few hours of trying to figure out why I couldn't download the release.
Offline jwaters125
« Reply #7 on: 2019 December 14 12:57:02 »
Then why did this work under the previous release?
« Last Edit: 2019 December 15 10:18:05 by jwaters125 »
« Reply #8 on: 2019 December 14 13:07:12 »
See our System Requirements page:
https://pixinsight.com/sysreq/
Windows 10 is the only Windows version supported officially since version 1.8.6 of PixInsight.
Offline jwaters125
« Reply #9 on: 2019 December 14 15:38:39 »
I am upgrading now.
Offline Poschinger
« Reply #10 on: 2019 December 16 09:14:08 »
I found this. Perhaps you can find out that it perhaps will be possible to use win7 for a longer time!
https://social.msdn.microsoft.com/Forums/de-DE/c6a48da4-f6d6-4d8b-af60-b2798d7238ba/systemfehler-quotapimswincoresynchl120dllquot-fehlt?forum=visualbasicde
Konstantin
Offline Andres.Pozo
« Reply #11 on: 2019 December 16 09:46:37 »
Konstantin
If you think that that link is interesting, could you please translate it?
« Reply #12 on: 2019 December 16 11:23:50 »
We have uploaded new Windows installation packages that should let you run version 1.8.8-3 of PixInsight on Windows 7 SP1 and Windows 8.1:
https://pixinsight.com/forum/index.php?topic=14446.0
