Author Topic: HaRGB  (Read 13538 times)
Offline papaf
Re: HaRGB
« Reply #15 on: 2009 September 27 01:43:46 »
Yeah, I would love to use wavelet to sort of bring out more, but everytime I try them, I am discouraged by the end result. Is there some tutorial on them? Or any general guidance I can follow? By the way, I had a problem (light leak) when I took this image. I already used ACNR to remove green. You don't want to know how bad it was before... ;)
Fabio
Offline Jack Harvey
Re: HaRGB
« Reply #16 on: 2009 September 27 06:29:43 »
Wavelets are difficult.  Using Atrous and not Atous V1 you can use the preview window which helps.  Maybe start by using one level such as adding 0.1 or 0.2 to the first level and see the result.  Trial and error is the method I use.  You might also try the HDR wavelets on Lum only?  GOod Luck
Jack Harvey, PTeam Member
