Author Topic: MaskGen - full star on subsequent executes  (Read 3975 times)
Offline SgtBilko
« on: 2019 December 10 13:43:22 »
MaskGen is a really great script (thank you Herbert).   On starting Pixinsight the 1st time I run MaskGen the "Mask Magnitude Range" min/max values produce the required star mask.  If I run it more than once, no matter what values I put into min / max for "Mask Magnitude Range" I get a full star field mask.   If I close Pixinsight down and reopen MaskGen again works flawlessley untiil I want to run it again.... same issue .... full star field.
Ian
Offline Herbert_W
Re: MaskGen - full star on subsequent executes
« Reply #1 on: 2019 December 10 19:33:12 »
Hi Ian!
All scripts on my website are by Hartmut Bornemann(!) -  I only provide the website.
With my version of PI the script works fine - see video:
https://www.skypixels.at/downloads/PI_Forum/Video_1_11122019.mp4
win10 pro, PI 1.8.8.2
Best regards!
Herbert, Austria
Offline bvalente
« Reply #2 on: 2019 December 10 21:52:53 »
Hi Ian
i found i solved my problem (unrelated, but maybe related?) by investigating the temp files.
i found it created two temp files, the second was empty. i deleted the second one and it seemed to fix my problems.
worth a shot?
Offline SgtBilko
« Reply #3 on: 2019 December 10 22:51:22 »
Hi Ian!
Best regards!
Herbert, Austria
My apologies......  and thank you Hartmut
Thank you for replying, Herbert.  I am running PI 1.8.8.2 and MaskGen 1.2.4.   The only diference between us is that I am running on a Mac 10.15.1.
Today it is even worse.  I cannont run the script at all.  It returns the following error:
*** Error [000]: /Applications/PixInsight/src/scripts/MaskGen.js, line 988: Error: Critical signal caught (11): Segmentation violation
PixInsight 1.8.8-1495 - Critical Signal Backtrace
Received signal 11 (SIGSEGV)
Module: 0 PixInsight 0x000000010ac04752 InitializePixInsightModule + 1849218
2: 1 libsystem_platform.dylib 0x00007fff6e316b1d _sigtramp + 29
1: 2 libsystem_malloc.dylib 0x00007fff6e2dde5e nanov2_malloc + 56
XXXXXXXXXX  EDIT XXXXXXXXXX
SOLUTION TO ERROR
I think I have solved the error.  I re-ran ImageSolve using defaults and it has not reappeared.
I re-ran MaskGen.  I can now run MaskGen repeatedly but it produces alternating results. See this video...
 https://www.dropbox.com/s/txlt2rb6vc5g58y/Screen%20Recording%202019-12-11%20at%2008.32.37-low%20frame%20rate%20MPEG-4.mp4?dl=0
« Last Edit: 2019 December 11 00:39:30 by SgtBilko »
Offline SgtBilko
« Reply #4 on: 2019 December 10 22:53:24 »
Hi Ian
worth a shot?
Thank you for taking the time to reply.
I have looked and MaskGen only creates one temp file on my system.
