Author Topic: Save for the Web  (Read 7166 times)
Offline twade
Save for the Web
« on: 2009 September 24 11:09:35 »
Dear PTeam,
It would be nice to have an option of "Save for the Web".  Basically, a "Save for the Web" would save a jpeg with a sRGB profile and a resolution of 72 dpi.  In other words, the "Save for the Web" would override whatever profile you have setup for RGB images.
Wade
Re: Save for the Web
« Reply #1 on: 2009 September 24 11:36:14 »
Interesting. I've noticed that saving the image in a format that's suitable for publishing or post processing is a bit disruptive. I typically process 32 bit float TIFFs and then save to 16b TIFF for finishing touches in PaintShopPro. So then I have to do a save-as to image_16.tif for example. Now my original image in PI has a different name. That's no good.
So now I do:
- clone the image
- save the clone in the desired format
- kill the clone
This leaves the original alone. Adding an 'Export' menu option where we can configure any of the supported formats (including Wade's suggestion) would fix that. I think the 'Export' menu item is more generic than 'save for the web' but would accomplish the same thing.
Thanks for bringing this up Wade!
Offline Simon Hicks
« Reply #2 on: 2009 September 24 11:43:45 »
Seconded.  8)
« Reply #3 on: 2009 September 24 11:58:17 »
Great idea!
« Reply #4 on: 2009 September 24 12:37:55 »
I guess that I could write a process that does this job...
« Reply #5 on: 2009 September 24 13:59:59 »
And folks ask me why PI is 'better' than any other image processing program out there?
Here, with PI, you can make a request, have it discussed, agree on a reasonable solution, and probably have it coded up and released back to you in a matter of days.
Try and get THAT kind of service anywhere else !
Offline Harry page
« Reply #6 on: 2009 September 25 11:23:22 »
Hi Carlos
Nice to have you back in the fold
Harry
Harry Page
« Reply #7 on: 2009 September 25 16:08:50 »
I've been thinking about this problem, and I'm not fully convinced that a process is the proper answer... everything is already implemented, so it would be quite easy to create a new script... But, that would have the problem of batch processing... I'll make the solution tomorrow, either a module or a script.
« Reply #8 on: 2009 September 27 10:44:38 »
Just to let you note that the process is almost finished. I'm having some coding problems, so I'll need more time (to ask for some help :P ).
