Author Topic: Problem Checking for Updates  (Read 844 times)
Offline wlickteig
« on: 2019 December 03 08:18:44 »
I keep receiving the following error message when checking for updates:
https://pixinsight.com/update/1.8.8-2/: Parsing repository update information: Parsing platform element (line=49 offset=3): Invalid platform 'version' attribute value '1.8.8-1:1.8.8-2'
https://pixinsight.com/update-doc/1.8.8-2/: Parsing repository update information: Parsing platform element (line=73 offset=3): Invalid platform 'version' attribute value '1.8.8-1:1.8.8-2'
Any ideas what to do?
Re: Problem Checking for Updates
« Reply #1 on: 2019 December 03 08:49:48 »
This happens because you have executed version 1.8.8 after running version 1.8.8-2. This problem should not happen under normal working conditions.
Do the following to solve this issue:
- From the main menu, select Resources > Updates > Manage Repositories.
- On the Manage Update Repositories dialog, click Default, then OK.
This will reset update repositories to the default ones required by the running PixInsight application.
Offline wlickteig
« Reply #2 on: 2019 December 03 09:38:14 »
Thanks Juan!  That fixed it...
Offline PeterLive
  • PeterLive
« Reply #3 on: 2019 December 03 14:12:39 »
Thank you so much.
Updates sorted.
