Author Topic: PI Log or Dump File? / PI Running In Debug Mode?  (Read 969 times)
Offline jwaters125
« on: 2019 November 30 19:14:32 »
Does PI create a log-file or create a dump when something happens?  My Win7 laptop has Blue Screened several time running Rel 1.8.8-2 with WBPP Rel 1.4.2.  There's nothing in my Win7 Pro Mini-Dump location.  Does PI keep track of its executions?
Can PI be run in debug mode?
Re: PI Log or Dump File? / PI Running In Debug Mode?
« Reply #1 on: 2019 November 30 20:10:37 »
at least on OSX when a process terminates abnormally there is a logfile generated by the system that shows which thread crashed and what the call stack was for that thread (and all the other threads too.)
on windows, i don't know. there is an "event viewer" but i've had limited success on postmortem analysis using that tool.
PI can be run from the command line, and it does output a couple of things here and there to the console, but it's not too much.
don't know about debug mode, juan would have to comment.
Offline jwaters125
« Reply #2 on: 2019 November 30 20:36:06 »
Thanks Rob.  Windows 'Event Viewer' is mostly useless for these things.
« Last Edit: 2019 November 30 20:50:00 by jwaters125 »
Offline John_Gill
« Reply #3 on: 2019 November 30 22:22:09 »
When Windoze has a blue screen there is normally an error code like 0x000012345, displayed for a second or two before the pc reboots. If you can get that code, then a Google search will indicate what the problem is.
Hope this helps
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
