Author Topic: 1.8.8-2 iMac 10.14.6 possible ImageIntegration rescaling issue  (Read 1415 times)
Offline mschuster
Hi Juan,
On this example, ImageIntegration generates this message:
* Rescaling output image. Integration range: [-1.37814204e-03,8.56981397e-01]
However the ImageIntegration output is not in the full range [0, 1] as I expected, instead it is [2.931992e-03, 9.946846e-01].
Is this a bug?
Zipped folder, with all frames, LocalNormalization reference and results, Integration results and log, and process icons.
The negative pixels were generated by using a low median LN reference.
https://www.dropbox.com/s/vqy07zhb20iotks/Rescale.zip?dl=0 (133 MB)
Re: 1.8.8-2 iMac 10.14.6 possible ImageIntegration rescaling issue
« Reply #1 on: 2019 November 30 09:46:57 »
Hi Mike,
You are reading clipped statistics. Check the Unclipped option on the Statistics tool and you'll get minimum=0 and maximum=1, as expected.
Offline mschuster
« Reply #2 on: 2019 November 30 09:51:39 »
Hi Juan,
Thank you, I forgot about that.
« Reply #3 on: 2019 November 30 09:53:57 »
No problem, it happens to me all the time ;)
