Author Topic: Merging Process Icons  (Read 713 times)
Offline straittalk1947
« on: 2019 November 28 10:58:36 »
When I’m working in workspace 2 with a set of icons and I want to merge in another set of icons from an .xpsm file, when I execute the Merge command, the new icons merge into workspace 1 rather than workspace 2.  If I try to move those new icons from workspace 1 into workspace 2, workspace 2 picks up not only the new icons from the .xpsm file but also the icons which were already in workspace 1.  So, how can I merge a selected set of icons into workspace 2?
Offline John Massey
Re: Merging Process Icons
« Reply #1 on: 2019 November 28 11:22:15 »
If you merge process icons they default to the workspace that you saved them in. If you load process icons then existing process icons will be replaced. I have set up different work spaces for tasks and save the process icons to that work space. I move my working images to those work spaces for processing. Hope that helps.
« Reply #2 on: 2019 November 29 11:37:10 »
Yes..........moving the working image takes care of my workflow rather than trying to merge the Process Icons.  Thanks for the suggestion!
