Author Topic: Mure DeNoise Detector Settings  (Read 5331 times)
Offline tdgm
« on: 2019 November 26 16:18:11 »
Hello
I have a question on the value for the Flat frame exposure numbers. When I run the script it comes uo with a number ~9458. But hen you say that in your opinion that the expsoure should be between 30-70% of full well which for 16 bit camera (65553 ADU) would be starting at 30,000 not 9000 range so what is that FLAT FRAME Expouser number?
Offline mschuster
Re: Mure DeNoise Detector Settings
« Reply #1 on: 2019 November 27 08:40:47 »
Hello Steve,
Is 30,000 e- camera full-well depth? If so, then a 9,458 e- exposure is OK, that is just larger than 30% of 30,000 e-.
In comparison, if Flat frame exposure were say 2,000 e- that that would indicate under-exposed flats.
The script does not know full-well depth, as it can depend on camera bit-width which is also unknown, so it just provides the measurement for you to double-check.
Flat frame exposure is trying to provide the typical flat-frame exposure in e-. More precisely, it is the median of the center-cropped and bias- or dark-subtracted flat frames in DN multiplied by gain in e-/DN to obtain a value in e-.
Offline tdgm
« Reply #2 on: 2019 November 27 09:03:34 »
Hi Mike
1st Off Happy Thanksgiving
Also thanks for the reply. I checked the full well capacity specs on my canera and there site syas >17,000. I also checked for my frame of mind and divided the flat frame exposure by your calculated gain and cane up with a DN of 31526 which is a little less than the 50%b of adu I was shooting for, so thanks again and have a clear great holiday season
Offline Pompey Monkey
« Reply #3 on: 2020 January 06 07:46:11 »
I don't use the Detector myself:
The median noise value can be found by multiplying the total DN for the camera by the image noise (from FITS header or Noise Evaluation script).
The gain (e-/DN) can be found by dividing the full well depth (in electrons) by the total DN for the camera.
Although these derivation rely on the manufacturers information, I find that they work well.
Offline niccoc1603
« Reply #4 on: 2020 January 07 23:00:26 »
Hi can you make an example? I have an ASI1600MM and manufacturer gain/RN values are reported on ZWO website (although they are in 12bit scale so they should probably be adjusted to 16bit)
