Author Topic: Weighed Batch Processing Script fails to complete - invalid drizzle path  (Read 1636 times)
Offline glatiak
I have been using the 1.35 version without issues. Got the update notice and installed the 1.41 version and have tried it twice. Both runs failed to complete - exception attempting integration - invalid drizzle path.
greg latiak
Offline eweigand
I'm also having the exact same issue.  I did find that the script completes successfully if I uncheck "Generate drizzle data" under Image Registration, however, I lose the drizzle data (obviously).  I can see from the console that the FITS keyword that is used by the script is WBPPWGHT, so I suppose I could just use the script to calibrate and register, then integrate manually using this keyword, but it would be nice if the script could integrate using the drizzle data.  Hopefully this bug gets fixed soon.
We cannot reproduce this problem with the WBPP script. It always generates drizzle files correctly in all of our tests.
Can you provide a data set where this problem can be reproduced?
Offline eweigand
Hi Juan,
Thanks for the response. The script generates the drizzle data files correctly, the issue is when we try to integrate the images using the WBPP, it says it can't find the drizzle files. It does create the drizzle files correctly, it just seems like the script is looking in the wrong location for these files when integrating the images.
