I was excited to read about the WBPP script. I updated PI and downloaded and installed the new script. I decided to run the same M45 data just completed on the standard BPP script. All the information was loaded and checked. The Diagnostics button was "Completed and OK", so I ran the script. The result was a Smart Report with errors and not stacked data. Here is the text of that report. Not sure what to do next?
Group of 15 Light frames
BINNING : 1
NoFilter
Exposure : 600.00s
[Calibration data]
Master bias: Z:/SRO files/20190501/master/bias-BINNING_1.xisf
Master dark: Z:/SRO files/20190501/master/dark-BINNING_1-EXPTIME_600.xisf
Master flat: Z:/SRO files/20191118 M45/master/flat-FILTER_B-BINNING_1.xisf
Calibration completed
Cosmetic Correction OK
Group of 12 Light frames
BINNING : 1
NoFilter
Exposure : 600.00s
[Calibration data]
Master flat: Z:/SRO files/20191118 M45/master/flat-FILTER_G-BINNING_1.xisf
BINNING : 1
NoFilter
Exposure : 600.00s
[Calibration data]
Master flat: Z:/SRO files/20191118 M45/master/flat-FILTER_R-BINNING_1.xisf
Reference frame for registration: Z:/SRO files/20191118 M45/M45 RGB-S001-R001-C001-B-PA000 Ref.xisf
BINNING : 1
NoFilter
Exposure : 600.00s
Registration OK
Frame weights succesfully computed and stored after registration
!!! Error: Error integrating light frames.
BINNING : 1
NoFilter
Exposure : 600.00s
Registration OK
BINNING : 1
NoFilter
Exposure : 600.00s
Registration OK
Second and Third Issue:
And that's not all. I tried making a drag copy of the script with all parameters inserted, using the New Instance triangle. I usually do this to reuse the scripts setup from target to target with new data. Almost none of the information was saved, no Lights, Flats, Darks or Bias frames were there when I used the New Instance copy to restart the script. The reference frame and directory link were retained. This has always worked in the past.
Another issue. None of my saved Batch Preprocessing copies work either. they all give an Error: Source code MD5 checksum mismatch:
This means all my saved setups for the various rotation angle that are saved in Batch Preprocessing new instance icons are lost in the latest install of PI.
I would appreciate some guidance on what to do next.
Thanks. Eric
