Author Topic: Unable to download repository information - Error  (Read 1370 times)
Offline jwaters125
« on: 2019 November 19 14:00:04 »
Just did a reinstall.  From Error Log.  Is the site down?
EDIT - I am running Win 7 Pro x64.
https://pixinsight.com/update/1.8.8-1/: Parsing repository update information: Parsing platform element (line=30 offset=3): Invalid platform 'version' attribute value '1.8.8:1.8.8-1'
https://pixinsight.com/update-doc/1.8.8-1/: Parsing repository update information: Parsing platform element (line=79 offset=3): Invalid platform 'version' attribute value '1.8.8-1:1.8.8-1'
« Last Edit: 2019 November 19 14:22:40 by jwaters125 »
Offline myxlflik
Re: Unable to download repository information - Error
« Reply #1 on: 2019 November 19 14:11:25 »
I have received the same message but it seems to only be happening with the linux install.  My MacOS install seems to be updating properly.
Offline jwaters125
« Reply #2 on: 2019 November 19 14:21:48 »
Its for Windows too.  I am running Win 7 Pro x64.
Offline jwaters125
Re: FIXED Unable to download repository information - Error
« Reply #3 on: 2019 November 20 07:21:46 »
Fixed.  I was forced to do a complete reinstall.
« Last Edit: 2019 November 20 11:44:24 by jwaters125 »
Offline mchaser
« Reply #4 on: 2019 November 30 08:12:16 »
I'm getting this error.  W10.  Reinstall did not help.
https://pixinsight.com/update-doc/1.8.8-1/: Parsing repository update information: Parsing platform element (line=85 offset=3): Invalid platform 'version' attribute value '1.8.8-1:1.8.8-1'
« Reply #5 on: 2019 November 30 09:27:08 »
This happens because you have executed version 1.8.8-1 after running version 1.8.8-2. This should not happen under normal conditions.
To fix this issue, do the following:
- From the main menu, select Resources > Updates > Manage Repositories.
- On the Manage Update Repositories dialog, click Default, then OK.
This will reset update repositories to the default ones required by the running PixInsight application.
