www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
Bug Reports
PixInsight crashes in StarAlignment while attempting "Register/Union - Separate"
« previous
next »
Print
Pages: [
1
Author
Topic: PixInsight crashes in StarAlignment while attempting "Register/Union - Separate" (Read 1003 times)
cgoodric
Newcomer
on:
2019 November 15 21:35:41 »
I was attempting to create a registered panel for one side of a 2 panel mosaic, when PI crashes. No error message was given, PI simply closes. The console says it's at 93% while calculating recursive surface subspline when the crash occurs. I'm not sure where console messages are logged, but I can make it available if you let me know where to look. I made 4 attempts and crash occurs at the same place each time as far as I can tell. The other registered panel created fine using the same reference image.
PI version: 1.8.8-1, all updates applied.
System info: Windows 10 x64, Intel Core i7-7820 (8 cores) 3.6 GHz, 16 Gb mem
Screen shot showing StarAlignment settings:
https://drive.google.com/file/d/11d08EPayOqfPdnddV_3sv-CWf1GM6HH9/view?usp=sharing
I can make a zipped pxiproject folder available if needed (6Gb.)
Calvin.
Logged
PTeam Member
PixInsight Jedi Grand Master
Re: PixInsight crashes in StarAlignment while attempting "Register/Union - Separate"
Reply #1 on:
2019 November 18 12:56:58 »
Hi Calvin,
This should not happen, so you probably have hit a bug in the StarAlignment tool. Can you please upload the images you are trying to register, so I can make tests?
Logged
cgoodric
Newcomer
Reply #2 on:
2019 November 19 09:30:34 »
Juan,
Thanks for your reply. I've made the pxiproject available on Google Drive (6Gb). Once you've loaded the project, you should only have to run the StarAlignment tool on the open image.
https://drive.google.com/file/d/1YJtkuBuG8uwJNsHLi6yksQWkIjBCy9C5/view?usp=sharing
Thanks!
Calvin.
Logged
Print
Pages: [
1
« previous
next »
PixInsight
Bug Reports
