Author Topic: Calibrating Flats "Incompatible Geometry"  (Read 706 times)
Offline UlteriorModem
« on: 2019 November 13 10:04:28 »
Greetings,
Yesterday I was preparing a new set of flats for a new filter configuration.
Using an ASI1600mc I shot the three sets of flats for three different gain and offset settings. It records images in fits format.
I then shot a set of 'dark flats' with the same gain and offset and duration as the flats. Then created a master dark flat.
When I go to calibrate the individual flat subs to the corresponding master dark flat I get the 'incompatible image geometry'.
Obviously something got rotated somehow? Maybe when I created the master dark flat?
Anyhow I remember some setting in file explorer but cant remember exactly what.
What has changed? I have been calibrating flats with master darks with no issues for years. Now all of a sudden something changed.
I am not at the machine(s) with the images or PI but wanted to put a feeler out so when I do get home I might have a better idea of where to start.
Thanks!
Offline aworonow
    • Faint Light Photography
Re: Calibrating Flats "Incompatible Geometry"
« Reply #1 on: 2019 November 13 10:15:15 »
not sure on the constraints for OSC, but maybe the images that are grayscale should be RGB, or the other way around.???
« Reply #2 on: 2019 November 13 10:53:47 »
No it is complaining about geometry not the CFA array.
I am used to seeing the 'forced' CFA message when running BPP.
« Reply #3 on: 2019 November 14 06:14:15 »
I looked into this a little further though I dont really know what the issue is. The frames have exactly the same x & y geometry.
I 'think' it has to do with trying to apply a master dark .xisf file to the .fit flats.
Batch converted all the .fit flats to xisf and the process runs, although now it states Warning: No correlation between the master dark and target frames. This is of course due to the CFA array but the calibration routine does not force the CFA pattern. I also tried "Force CFA" and still had some error message.
