Author Topic: DynamicProfile module available in win32 and win64  (Read 6220 times)
« on: 2009 September 16 20:57:40 »
get the dlls here:
http://www.tungstentech.com/Portals/0/downloads/Profile-pxm-win64.zip
and
http://www.tungstentech.com/Portals/0/downloads/Profile-pxm-win32.zip
Installation: Unzip the contents into your c:\PCL\bin or elsewhere to keep this module separated from the stock PixInsight modules. Use the Process->Modules->Install Modules feature in PI to install the module. It will reload automatically next time you start PI, even when the module gets updated.
This newest version is compiled for the latest PCL (PI 1.5.6 compatible) and fixes the cvs export.
Offline Andres.Pozo
Re: DynamicProfile module available in win32 and win64
« Reply #1 on: 2009 September 17 01:54:45 »
Thanks Sander,
this is a really useful tool.
Andrés
« Reply #2 on: 2009 September 17 06:07:52 »
Thanks Andres!
« Reply #3 on: 2009 September 17 23:36:38 »
Hey Sander! I used your tool today. Works really fine. Indeed our approaches seem different, although the interface looks similar (I'm reusing a lot from HistogramTransform). One big difference is that I made a static process, while yours is dynamic. I sorted the problem of manually setting the coordinates using an interactive input through the readouts. I created "starting coordinates" and "ending coordinates" modes, that are updated every time the user clicks on the image (this is very similar to what happens on the control image, plotting the pixel values in the Curves, for example).
Anyway, I was able to compile my old module, but is not working. Don't know if I left something uncompleted, or it needs lots of debugging :P Did I mention that it was some 2 years old? :P
Congratulations again for your work. Keep it coming ;)
