Author Topic: Starnet install  (Read 603 times)
Offline ballyhoo
Starnet install
« on: 2019 November 09 22:53:56 »
I am getting an error trying to test starnet. At the end of the process is tells me "permission denied." Does this mean Starnet will not work on my system? It is a relatively newer W10.
thank you
Re: Starnet install
« Reply #1 on: 2019 November 10 10:34:14 »
this is not the starnet PI module, it is the command line version. it should not be installed inside the PixInsight application folder. probably ordinary users don't have write access into that folder.
just put all that stuff somewhere else in your home directory and it should work.
Offline ballyhoo
Re: Starnet install
« Reply #2 on: 2019 November 10 11:03:35 »
thank you,
do you know where I get the module?
Re: Starnet install
« Reply #3 on: 2019 November 10 11:22:13 »
announcement post here:
https://pixinsight.com/forum/index.php?topic=13691.0
links are in the first post
