Author Topic: Subframe selector removes colour information  (Read 688 times)
Offline jdutton2
« on: 2019 November 07 06:31:27 »
Gentlefolk,
       I am quite new to PixInsight and I have encountered an issue with the subframe selector. I am imaging with a DSLR and importing my subs as "Pure Raw" files. The issue is that when I use the subframe selector to create "approved" subs with a weighting keyword added, I am unable to debayer them later in processing. (PixInsight complains that the colour information is missing). Any suggestions?
Thanks.
Offline dave_galera
    • QDigital Astro
Re: Subframe selector removes colour information
« Reply #1 on: 2019 November 07 07:05:21 »
You should debayer before you use SubframeSelector, see this post and answer from Rob
https://pixinsight.com/forum/index.php?topic=10215.0
This may also help:
https://pixinsight.com/forum/index.php?topic=10232.0
Dave
« Reply #2 on: 2019 November 07 09:05:23 »
well juan did subsquently say that SFS would mostly work on bayered data... but i guess its a little less than ideal to use bayered data.
i guess whats happening is that SFS is saving the files as xisf and theres no hint for what the bayer matrix should be.
if this is a canon DSLR i think you can set the bayer matrix to RGGB manually in Debayer and it should work out.
Offline jdutton2
« Reply #3 on: 2019 November 07 15:10:18 »
Thanks for the tips...I'll give it a try.
