Author Topic: BPP or BPPFD? How to properly use dark flats for flat calibration  (Read 578 times)
Offline dchamberlain
I've read the threads on BatchPreprocessing and BatchPreprocessingFD scripts and I must admit I'm a little confused as to the proper workflow. Questions are:
1. Can BPP (not FD) be used with dark-flats instead of bias frames and if so, how is that set up?
2. If BBFD must be used, what is the process for calibrating flat frames?
3. Are BIAS frames necessary at all for lights or darks? I have a CMOS camera (ASI1600).
Thanks!
Dale
Re: BPP or BPPFD? How to properly use dark flats for flat calibration
« Reply #1 on: 2019 October 28 20:37:56 »
i can't really answer #1, i think michael covington forked BPP (to create BPPFD) to add flat darks for DSLR processing. he's around her so i think he can answer.
if you want to use BPP with dark flats (or flats where the ISO/Gain is different than the lights) what you do is load some dummy lights, but load your real flat darks and flats and run it. this will result in a calibrated master flat file which you can save somewhere and then run BPP again with your lights, darks that match the lights, and the master flat. you just need to tell the script you are using a master flat (there is a check box).
usually CMOS cameras have some amp glows which preclude scaling of the darks, so there's no reason to use bias frames. i think your best bet is to always acquire matching darks for the flat and light durations and just skip bias frames. having said that i don't use a CMOS camera so maybe ASI1600 is an exception and scaling the darks would be OK.
Offline John_Gill
« Reply #2 on: 2019 October 29 02:30:16 »
I use an ASI1600mm cooled camera and I do not use Bias.  This is because for this camera, the short exposure is almost video speed.  Just use Darks and Flats for calibration.
space is not black
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
