Author Topic: PixInsight 1.8.7 Released  (Read 42705 times)
Offline Andres.Pozo
Re: PixInsight 1.8.7 Released
« Reply #45 on: 2019 October 05 03:33:05 »
I put 4 fotos 1-4 in
https://we.tl/t-e6anuf8IZO
1 is the right bottom corner of the mosaic.
I hope the link works.
Armando
Thanks ario. I can now reproduce the failure. However, it fails due to changes I am not responsible for. I have reported this so Juan is aware of it.
Offline astrojeff
« Reply #46 on: 2019 October 05 08:16:24 »
nice release but 1.5hrs to download the 228mb file?  Its been like this for days.  I have a 1G/1G connection.  Is there an issue with the Software Distribution site?
Offline JeffSeivert
« Reply #47 on: 2019 October 05 12:48:04 »
Thanks for the update to PI!
I'm having an issue when using the Batch Preprocessing Script in the new 1.8.7.  The screen goes black after a few seconds and never recovers.  Everything else seems to work fine.
I read the release notes and saw that there may be rendering issues on laptops with an Intel video card and I wonder if this is the problem.
My specs: Asus laptop, Core i7-4720 HQ CPU @ 2.6Ghz and 16GB RAM.
I also have Intel HD 4600 Graphics and NVIDIA GeForce GTX-950M (2GB) cards.
So my question, is there a way to force PI to use the GeForce card and hopefully avoid the rendering issue?
Otherwise, is my only option to go back to 1.8.6?  And out of curiosity, what changed between 1.8.6 and .7 regarding the rendering?
I uninstalled 1.8.7 and installed 1.8.6 and it ran perfectly with the same files.
Thanks for an awesome platform and support!
Jeff
« Last Edit: 2019 October 05 13:31:45 by JeffSeivert »
Offline Barry-Wilson
« Reply #48 on: 2019 October 06 10:06:15 »
Hi Juan
Like Brad I use an iMac with OS 10.14.6 Mojave and I too am noticing considerable delay in the real time preview window and, in general, a slower response time.
Is there anything I can do to help you diagnose if there is an issue?
Barry
10Micron GM1000HPS & 2000HPS II UP; QSI683wsg8; FSQ106, FSQ85, WO132FLT
My images: https://barrywilson.smugmug.com/
« Reply #49 on: 2019 October 06 11:18:38 »
Hi Barry,
As I said in my answer to Brad's post, I cannot reproduce this problem. Version 1.8.7 works perfectly fine on all of our working Mac machines. All of them run macOS 10.14.6.
The only thing I can figure out here is a third-party application interfering with PixInsight. Do you have some virus protection application, or a similar utility?
Offline Julien
« Reply #50 on: 2019 October 06 11:20:41 »
Have the INDI process been removed ? I can't find them since I installed the last version.
Julien
Julien
www.elendil.software
« Reply #51 on: 2019 October 06 11:30:43 »
Hi Jeff,
We cannot reproduce this problem. BPP runs normally on all of our working and testing machines, on all platforms.
On Windows, the PixInsight core application already attempts to use the discrete GPU exclusively on machines with dual graphics. This should work for both nVidia and AMD graphics cards. However, whether or not this works on a particular machine is a different thing; one never knows for sure on Windows, especially on laptops, where the concept of standards is pretty fuzzy. There is nothing more I can do to fix these issues.
What is really strange is that it works with 1.8.6 and not with 1.8.7. There are no changes at all that could justify such a different, and problematic, behavior.
« Reply #52 on: 2019 October 06 11:33:00 »
Hi Julien,
We are working on a completely new INDI support module, based on the INDIGO platform. So please be patient, it will be available again soon, and it will be much better than the old version.
Offline Alfredo Beltran
« Reply #53 on: 2019 October 06 13:20:48 »
Hi Juan
As always, thank you very much for all the work done to make new releases available for us.
I have made some calibration and integration processes for a 100 stack of dark and bias frames. I can notice a huge difference in the increase of time that it takes now (Windows 10 home), and also that PixInsight tries to use as much ram as it is available. I don’t know if that’s the cause to make the whole process slower.
Is this the expected behavior?
Alfredo
iOptron CEM60
Celestron 925 EdgeHD Hyperstar
MicroTouch Focuser
ZWO ASI071 MC Pro
Bogota, Colombia
http://www.flickr.com/photos/alfredo_beltran/
« Reply #54 on: 2019 October 06 14:05:54 »
Hi Alfredo,
The new automatic buffer sizes parameter of ImageIntegration is enabled by default. It is starting to become obvious that this has been a mistake, which I'll fix as soon as possible.
As described in the tooltip for this parameter:
Usually this is the best option to optimize image integration performance, but be aware that for large data sets and low-memory machines (relative to the total size of the data) the process may use too many system resources. If you want finer control on system resources usage, disable this option and tweak the values of the buffer size and stack size parameters.
So if your machine does not have RAM enough to integrate 100 frames at once, please uncheck the automatic buffer sizes option. This will return to the previous behavior.
Offline cplonski
« Reply #55 on: 2019 October 06 15:30:18 »
Arguably the most commonly used tool, Histogram transformation, the preview window takes a heck of a long time to open initially.
« Reply #56 on: 2019 October 06 15:55:16 »
Hi Alfredo,
Thank you very much Juan
iOptron CEM60
MicroTouch Focuser
ZWO ASI071 MC Pro
Bogota, Colombia
Offline johnpane
« Reply #57 on: 2019 October 06 16:57:05 »
Juan,
I think there is merit in the automatic optimal utilization of available memory even if not all the subframes can fit into memory. I hope this idea of automatic buffer sizes is not abandoned.
John
« Reply #58 on: 2019 October 07 02:31:51 »
This cannot be reproduced on any platform. You don't mention it so I assume you are a Windows user. The HistogramTransformation tool works without problems in real-time preview mode on Windows 10. It is as fast as it was in version 1.8.6, both for preview and for execution, and perfectly stable. I have just verified this again on two different machines running Windows 10 Professional.
This is a machine-specific issue, probably being caused by a wrong or defective graphics driver, or by conflicts with third-party applications. The behavior you are describing cannot be reproduced on any supported platform under normal working conditions.
« Reply #59 on: 2019 October 07 02:38:49 »
Hi John,
No, of course I won't abandon it, since I agree this feature is very useful. My mistake has been enabling it by default without more 'protection' for users trying to integrate huge data sets on weak machines. I am going to add a new parameter to control the maximum fraction of the available memory that ImageIntegration is allowed to use. I hope this parameter, with a default value of 0.8 for example (so the machine will always have at least a 20% of free memory), will help prevent cases where the automatic buffer sizes feature is causing problems by exhausting resources.
