Author Topic: Starnet Problem  (Read 1941 times)
Offline STEVE333
    • sk-images
Starnet Problem
« on: 2019 September 30 16:09:00 »
I've been using Starnet successfully as a PI Process for some time.
However, when trying to run it today (9/30/2019) I get the error message  "Checkpoint file not found!" and the process doesn't run.
Any ideas?
Camera:  Canon T3 (modified)
Mount:  CEM40 EC
Offline STEVE333
    • sk-images
Re: Starnet Problem
« Reply #1 on: 2019 September 30 16:18:45 »
I saved the files, closed PI, restarted it, and, the problem went away. I was able to reload the image in question and run the Starnet Process on it successfully.
I feel a bit foolish, but, glad for the happy outcome.
Mount:  CEM40 EC
Offline airscottdenning
Re: Starnet Problem
« Reply #2 on: 2019 September 30 17:33:12 »
In the PI Process Console, type:
cd /bin/PixInsight
Offline STEVE333
    • sk-images
Re: Starnet Problem
« Reply #3 on: 2019 September 30 17:42:28 »
cd /bin/PixInsight
Thanks for the response.
Since the Starnet process is now working should I still type the code into the Process Console?
Is this a one-time fix?
Mount:  CEM40 EC
Re: Starnet Problem
« Reply #4 on: 2019 September 30 18:37:53 »
i think you'd have to do that if it stops working again and will need to be done each time it stops working the first time after launching PI.
Offline STEVE333
    • sk-images
Re: Starnet Problem
« Reply #5 on: 2019 September 30 19:37:44 »
Thanks Rob. The funny thing is that when it didn't work and I closed PI then reopened it, loaded the same image, and then ran the Starnet process, it worked. I'll never understand computers.
Mount:  CEM40 EC
Offline Kinch
Re: Starnet Problem
« Reply #6 on: 2019 September 30 22:37:52 »
"The funny thing is that when it didn't work and I closed PI then reopened it, loaded the same image, and then ran the Starnet process, it worked."
I found myself doing that quite often!
Offline drmikevt
Re: Starnet Problem
« Reply #7 on: 2019 October 02 08:35:24 »
Can I ask a Starnet++ question, please?  I've been running it through the Terminal on Mac since (I think) there is no PI module for Mac.  Is there any benefit to running Starnet as a PI module as opposed to saving the file and running it externally?  Does the file still have to become a 16bit TIFF when using the module within PI?
Re: Starnet Problem
« Reply #8 on: 2019 October 02 08:51:18 »
i *think* that the module can handle non-16 bit data, but i don't know how (meaning, it might internally convert whatever you have to 16b before running).
there is no module for OSX, but the source code is released. i don't think it's a simple matter of just building it though, because nikita could not get it to work on OSX.
Offline Stu
Re: Starnet Problem
« Reply #9 on: 2019 November 27 17:01:04 »
cd /bin/PixInsight
Hi, just mining the forum.  This just started up for me too.  It has previously worked.  I tried typing the above into the process console and I got "*** Error: The target directory doesn't exist: /bin/PixInsight"
I tried uninstalling and reinstalling the program, and also reinstalling the Starnet process and I still get the same problem.
Any ideas?
Stuart
Offline Stu
Re: Starnet Problem
« Reply #10 on: 2019 November 27 17:10:35 »
Howdy,
Never mind, found the problem.  I was typing it incorrectly.  Found another post and this is what I needed to type
cd "C:/Program Files/PixInsight/bin"
Offline astrovienna
Re: Starnet Problem
« Reply #11 on: 2019 November 28 10:11:44 »
Howdy,
Thanks Stu.  I just ran into the same problem, and that worked for me as well.
Kevin
Re: Starnet Problem
« Reply #12 on: 2019 November 28 14:41:35 »
There IS now a StarNet PI module for MacOS!
See https://www.cloudynights.com/topic/651745-starnet-star-removing-software/page-10?hl=+starnet message #246
Or go straight here:
https://sourceforge.net/projects/starnet/files/PixInsight_module/
Much more convenient than the outside executable, plus I think the PI module is updated whereas the outside executable is not.
Cheers!
Offline Stu
Re: Starnet Problem
« Reply #13 on: 2019 November 29 16:52:06 »
I'm finding that I have to put that expression in repeatedly, every time I start up PixInsight.  Is there anyway to make it stick?  I have a text file on my desktop that has it on it, but it is annoying.
Stu
Re: Starnet Problem
« Reply #14 on: 2019 November 29 20:31:35 »
unfortunately if PI starts up with a different working directory, then you'll have to do the CD thing every time. not sure it can be scripted, but maybe. i have never tried to put a cd command in the startup script.
