Author Topic: BMP format Default  (Read 4222 times)
Offline Jack Harvey
BMP format Default
« on: 2009 September 03 11:22:26 »
With the new version of PI in Mac I find when I go to dave an image the default is BMP (something I never use).  I would prefer the default to be .fits and am sure there is a way to change it but darned if I can find it?
Jack Harvey, PTeam Member
Offline Philip de Louraille
Re: BMP format Default
« Reply #1 on: 2009 September 03 17:32:01 »
Under Edit | Global Preferences, select File I/O Settings    ;
Under the "Default image file extension" enter .fit    ;
I also have "Remember File Save file type" checkmarked though I do not know if this is important.
Philip de Louraille
Offline Jack Harvey
« Reply #2 on: 2009 September 04 10:04:10 »
Thanks, unfortunately mine is set up just like that and I still get BMP as a default?
« Reply #3 on: 2009 September 04 23:05:39 »
Well! That took some hacking!
I realized that I had not tried what you were describing but once I did... yes siree... BMP is the first choice.
OK, try this although it is like throwing the baby along with the bath water. Many formats become invisible but FIT is NOT one of them. ;-)
Launch PI, access menu:
Process | Modules | Manage Modules...
Find the one named BMP-pxm.dylib and double click on it and it becomes disabled.
Quit and relaunch PI. Voila. FIT is now first.
If you want to go back to the past, use Process | Modules | Install Modules
You may see nothing in the list although you know BMP is disabled. Make the module visible by pressing on the Search button below. Voila. You may now press Install and PI is back to its original state. Well almost. Because BMP is not module 1 any longer. If that is important... that I do not know.
Philip de Louraille
« Reply #4 on: 2009 September 05 03:12:38 »
Hi Jack,
This is actually a bug. It will be fixed in the next version.
Philippe, you've found a very nice and smart workaround! ;)
Sorry for the inconveniences!
Offline Jack Harvey
« Reply #5 on: 2009 September 05 06:12:05 »
Perfect  Thanks Phillip and Juan
