Author Topic: AnnotateImage Script: Add DWB catalog?  (Read 607 times)
Offline joelshort
    • Buckeyestargazer.net
« on: 2019 August 31 08:35:52 »
I'd like to add the DWB catalog as a custom catalog in AnnotateImage, but I can't seem to find it in Vizier.  Is there another way to add the DWB catalog?  I'm not very clear on the procedure so any help would be appreciated.
Joel Short
www.buckeyestargazer.net
Offline oldwexi
    • Astronomy Pages G.W.
Re: AnnotateImage Script: Add DWB catalog?
« Reply #1 on: 2019 August 31 12:01:00 »
the DWB catalogue is part of the SIMBAD Catalogue in Vizier.
You go on:
http://adsabs.harvard.edu/abs/1969A%26A.....1..270D
select   SIMBAD Objects  194
Change the output options to ASCII with "; separator"
Cut and paste the result in an editor for preprocessing and
later into Exel for final format creation for the custom catalogue.
Be careful the separators should be finally Tabs !!!
Also note that this catalogue does only provide object number and coordinates.
There is no Mag and Diameter information there.
I would paste simply Mag 10 and diameter 5 minutes in all columns.
Hope this helps
Gerald
P.S.: I have the complete TExtfile here:
http://www.werbeagentur.org/oldwexi/DWB.txt
You only need to adapt it for the CustomCatalogue
Offline joelshort
« Reply #2 on: 2019 August 31 16:49:23 »
You go on:
Hope this helps
Gerald
Thanks.  A lot of editing to do but I got it.
Joel Short
Offline joelshort
« Reply #3 on: 2019 September 02 10:15:57 »
If anyone is interested, attached is the txt file for the DWB catalog. This only includes the Name, RA and DEC.
Joel Short
